Home > Puma (Tdci) > Difference between Bell Auto Service and ALIVE
Page 3 of 4 <1234>
BigWheels
That last point worries me. Confused
Am I tied to the licensee? If it closes down, how do I get updates etc, and do these re-maps have renewal charges (as some computer software does?
Perhaps I should just try a different exhaust system.... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #282101 14th Nov 2013 12:20pm
bell-auto-services
If you have had it done by ANY licensee/installer no matter which you choose and they closed down, updates could not be done unless the business was sold to someone who would contiune support of existing sales and products. This is the same with anything for sale at all on the market really I suppose so is actually hard for anyone to answer any different.
Re dealer updates, generally the installer could and would install a new remap if needed at no extra cost if your dealer were to make a software update to your car.
Pete
Post #282103 14th Nov 2013 12:30pm
Porny
Site Sponsor
Are you talking about using one of the remote interface boxes? So that you can have your vehicle 'mapped' via email?
If so, I'm not really a fan of this method without the use of addtional tools.... but obviously the choice is yours.
The interface is tied to the reseller - and then once used is paired to your vehicle only. The boxes can be 'reflashed' but you can only ever have files from the initial 'reseller'.
Regardless of all of this - my point referes to LR software (and it is very unlikely there will be any more 2.4 software updates)...
You need to make sure you have the latest standard software on your vehicle before any modifications are made. There is no point having an outdated file on your vehicle modified.
Over the lifetime of the 2.4, LR have released a lot of software updates/improvements - and you want this latest file on before you do anything. This can only be done using a dealer spec IDS/SDD system or an update to Blackbox Solutions Tool or Autologic. It cannot be done via the 'Atric' Box or any other tuning interface box.
Then, once any changes have been made to a calibration (regardless if you have just updated the calibration or flashed the ECU with a uprated version) you MUST redo the injector pump learn and more importantly the pilot injection learn. This is critical to correct operation of the fuel system - especially on a common rail. Anyone that says otherwise does not have a full understanding of the Tdci set-up.
But if you are just talking about the company as whole - then it is as above as per Pete has said. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #282120 14th Nov 2013 1:21pm
steeplejack
Wales 2013 Defender 110 Puma 2.2 USW Santorini Black
BigWheels wrote:
I don't want extra speed, but do torque.
Is a map still best or would a plug-in gadget such as Terrafirma sell be as good, if not cheaper.
To those who have mapping, what difference has it made to your insurance premiums & what insurance companies are best for that kind of modification.
My insurance is £240 p/a with replacement ECU. Quote was £216 without so 11% increase
This is a fully comp policy with LV, max NCB
HTH
Post #282531 15th Nov 2013 8:28pm
bell-auto-services
If additional tools arnt available or pratical to use with an off the shelf application device its not all grim, one could always build a self extracting diagnostic routine from one of the many used set up routines seen and used daily in SDD directly into the mapping tool interface flash software. DRIVE_CYCLE_L316_Fuel_System_Pressure, thats if of course one can extract the Exml file instruction set it uses into plane text as seen below Thumbs Up
I do find it a shame JLR havent updated or made more user friendly a lot of their setup routines since 3 July 2007 as with the Fuel system pressure profile #2 : routine Big Cry
<profile_name>
<tm>
</profile_name>
- <help_text>
<tm>
</help_text>
- <pre_cycle>
<state_model_process>STATE_VALUE_ENGINE_RUN</state_model_process>
<stall_warning>FALSE</stall_warning>
</pre_cycle>
- <post_cycle>
<completion_delay>10000</completion_delay>
<state_model_process>STATE_VALUE_IGNITION_OFF</state_model_process>
- <Matches>
<create_log_file>TRUE</create_log_file>
</post_cycle>
<module>PCM_SYSTEM_A</module>
<simulate_comms>FALSE</simulate_comms>
- <SIMULATE>
<module_sec_driver_level>2</module_sec_driver_level>
<connect_session>EXTENDED_UNLOCKED</connect_session>
<disconnect_session>DEFAULT</disconnect_session>
- <signal_group>
- <signal>
<name>ESTIMATED_FUEL_RAIL_PRESSURE</name>
<class>DISPLAY</class>
<transform>TRANSFORM_ESTIMATED_FUEL_RAIL_PRESSURE</transform>
<tm>
</signal>
- <signal>
<name>DID_ENGINE_RPM</name>
<class>READ</class>
<service>0xF40C</service>
<transform>TRANSFORM_DID_ENGINE_RPM</transform>
<tm>
</signal>
- <signal>
<name>DID_ENGINE_COOLANT_TEMPERATURE</name>
<class>READ</class>
<service>0xF405</service>
<transform>TRANSFORM_DID_ENGINE_COOLANT_TEMPERATURE</transform>
<tm>
</signal>
- <signal>
<name>DID_FUEL_RAIL_PRESSURE</name>
<class>READ</class>
<service>0x050D</service>
<transform>TRANSFORM_DID_FUEL_RAIL_PRESSURE</transform>
<tm>
</signal>
- <signal>
<name>ROUTINE_FUEL_RAIL_PRESSURE_TEST</name>
<class>WRITE</class>
<service>0x1670</service>
<transform>TRANSFORM_ROUTINE_FUEL_RAIL_PRESSURE_TEST</transform>
<tm>
</signal>
</signal_group>
- <profile>
- <Control>
- <timebase>
<duration>300</duration>
<sample_interval>200</sample_interval>
<time_points>000,010,020,030,040,050,060,070,080,090,100,110,120,130,140,150,160,170,180,190,200,210,220,230,240,250,260,270,280,290,300</time_points>
- <1>
</timebase>
- <signal>
<display_minimim>0</display_minimim>
<display_maximim>8000</display_maximim>
<value_points>
<limit_1>
<limit_2>
<limit_test_bounds_failure>
</signal>
- <signal>
<display_minimim>20</display_minimim>
<display_maximim>130</display_maximim>
<value_points>
<limit_1>95, 115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115,115</limit_1>
- <t>
<limit_2>
- <limit_test_bounds_failure>
<action>CRITICAL_STOP</action>
<tm>
</limit_test_bounds_failure>
</signal>
- <signal>
<display_maximim>120</display_maximim>
<value_points>
<limit_1>X, X, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, X, X</limit_1>
<limit_2>
- <t>
- <X>
<action>RECORD</action>
<tm>
</signal>
- <display>
- <signal>
<value_points>000,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,000,000</value_points>
- <t>
<limit_1>
<limit_2>
</signal>
- <signal>
- <t>
<limit_1>
<limit_2>
</signal>
- <alternatively>
- <transform>
- <read>
<data_type>unsigned</data_type>
<resolution>0.25</resolution>
<offset>0</offset>
<unit>RPM</unit>
<size>16</size>
<shift>
<mask>
</read>
<write>
</transform>
- <transform>
- <read>
<resolution>1</resolution>
<offset>-40</offset>
<unit>C</unit>
<size>8</size>
<shift>
<mask>
</read>
<write>
</transform>
- <transform>
- <read>
<resolution>0.0078</resolution>
<offset>0</offset>
<unit>MPa</unit>
<size>16</size>
<shift>
<mask>
</read>
<write>
</transform>
- <transform>
- <write>
<resolution>128</resolution>
<offset>0</offset>
<unit>MPa</unit>
<size>16</size>
<shift>
<mask>
</write>
</transform>
- <transform>
- <read>
<offset>0</offset>
<unit>MPa</unit>
<size>16</size>
<shift>
<mask>
</read>
<write>
</transform>
</profile>
</drive_cycle>
Post #282557 15th Nov 2013 10:04pm
LR90XS2011
with my LR approaching 3 yrs old (built in Feb 2011) how can I be sure that I have the latest software before I get a remap, Im not confident the francise dealer I use does anything properly DEFENDER 90 TDCI XS,
Post #282592 16th Nov 2013 7:19am
Porny
Site Sponsor
You could just come me Wink I have a full dealer level diagnostic kit....
Any company that offers any tuning updates should have the correct kit to do this in my opinion - but a lot of them dont Shocked
Ian IRB
Post #282593 16th Nov 2013 7:26am
LR90XS2011
Ian
thanks as you are local and clearly LR knowledgeable I already had you in mind for my 3 yr service and all other transmission fluids changes (assuming you do that type of thing) wont be until March/April and after its 3yr MOT and a few more warranty jobs that the dealers can sort. DEFENDER 90 TDCI XS,
Post #282601 16th Nov 2013 8:00am
Porny
Site Sponsor
No problem.... just give me a shout closer to the time.
Ian IRB
Post #282606 16th Nov 2013 8:06am
Tiger
So to conclude from reading this thread:
BAS & IRB seem to know there stuff to nth degree
Depends who's nearest to you Thumbs Up
Post #282616 16th Nov 2013 9:03am
BigWheels
On reflection, different mapping for different needs is where LR may have made a few more sales.
The Discoveries & RRs have a space shuttleload of maps & modes. All the Defender needs is for an owner with an ECU Defender to be able to choose more power &/or torque. Other manufacturers do offer alternatives, also axles etc to go with them.
Had LR done this already, I would have had one when I bought mine, & it was still in warranty. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #282645 16th Nov 2013 10:50am
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
I agree with you Tiger. Ian at IRB does know his stuff.
I travelled 450 miles to see Ian and Ada. A great experience. They pulled out all the stops to get my 110 finished in time.
The difference is amazing.
Post #283028 17th Nov 2013 8:17pm
bell-auto-services
Or who has the nearest dealer to you with the relevent tuning kit and dealer diagnostic tools on hand Thumbs Up
Post #283039 17th Nov 2013 8:39pm
Or which one you can get hold of Whistle
Post #283126 18th Nov 2013 7:45am
j33per
2013 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Was at home over the weekend (Netherlands) and had mine chipped by Rica in Wateringen. Outstanding service and it all worked! Nice to be able to use the iSoftloader to put it back to factory settings and to be able to upload the tuned settings... Good value and quality! www.j33per.net
Post #283258 18th Nov 2013 6:05pm
Page 3 of 4 <1234>
