Home > Maintenance & Modifications > Switch to turn off driving auxilary lamps but keep main beam |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
It is legal, you just need to put a switch in the trigger feed from the main beam wire to the relay. So where it is currently connected from the main beam cable directly to the relay yo turn it on there needs to be a switch in this cable run. There is no current through this it is only the trigger to turn the aux lights on. A simple on of switch would do the trick. $W33T $0U7H3RN $UG4R
16th Nov 2013 6:09pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I did just the thing today,
installed an ON - OFF - ON toggle switch so I have the choice between always on, always off or automatic with full beam: The aux lights will be controlled by relay, you just need to locate the relay by following the wire, then follow the wire from the relay. |
16th Nov 2013 8:15pm |
