Home > My Defender > X tech..
Page 17 of 21 <123 ... 161718 192021>
238kirk
United Kingdom 2003 Defender 90 Td5 SW Belize Green
Excellent, looking good Thumbs Up
Post #281381 11th Nov 2013 9:28pm
mcma1
Thanks for the contact details for Pete. Thumbs Up
Also finally pedals put on the CNC, machined, then anodised a dark graphite and finish machine the top surface. Looking forward to seeing the results.
Post #281487 12th Nov 2013 7:49am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Very nice, the only thing i would do is texture the surface so your feet dont slip off the pedals 2004 TD5 Defender 90 xs station wagon
Post #281727 12th Nov 2013 9:04pm
Scott90
1995 Defender 90 300 Tdi PU Coniston Green
Very nice, but to abide by mot laws you need some sort of rubber on the brake peddle to stop your foot slipping.
Post #281744 12th Nov 2013 9:35pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
mcma1 wrote:
Finally got started fine tuning a lot of annoying things. Fitted 2 new heated recaros with pull out bases onto some new rails, then started to remove the rear seats. Later in the week the fun will start as the bulkhead bar is going in and the rear seat boxes get adjusted, then new carpet. and a few other goodies!
How are those seats for comfort, I mean i am thinking about fitting those seats in my 110 but cant think if i should spend the money and get those or get the Elite seats!!
Post #281757 12th Nov 2013 10:18pm
mcma1
Making steady progress, fitting the carpet now and first seat back in. nice to seat more of the silver seat backs! then just to added the trims, pity the windows didnt get done at the same time.. Sad
i think the recaros are great for comfort.
Post #281853 13th Nov 2013 1:38pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Have you got a link for the carpet you used? Nearly finished dynamatting mine and have no solution on good carpet.....have 3 seperate rolls under the bed from 3 differennt sellers and they are all more like gauze.
Great work on the transformation. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #281861 13th Nov 2013 2:43pm
mcma1
I went with mega van mats velour trim to try and avoid the "fury" effect, seems ok and fairly close the front landrover carpet. I only have it under the seats as the floor will stay just Dynamat and the load area mat. pM me your address and I will send you a decent sample if you want?
Andy
Post #281866 13th Nov 2013 3:13pm
mcma1
Bit more done today, carpet finished, dynamat in the back floor and then the front seat box. Decided to use an Entreq bar to trim over the lip behind the bar, and just trimmed the rubber floor mat a little.. Just need to bolt the recaros in for good now and the second rear seat. Will take some better pictures when it all done but really pleased.
Post #282174 14th Nov 2013 5:59pm
Killer90
Site Sponsor
Another top day, love that entreq bar idea Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #282274 14th Nov 2013 9:20pm
mcma1
Cheers Chris,
Attention to detail is what makes these mods look right.
Post #282322 14th Nov 2013 11:30pm
mcma1
Both seats not back in,
just waiting to fit the second back seat unitl the landglass goes in. The seat mod panels differ slightly as the 45 degree lip doesnt run the full length so you end you with awkward little faces to carpet, rather then waste time trying and to avoid any edges i just trimmed so 5mm mdf panels over these and then the seat bracket cover sit nice and tight up to these. Also i can then screw a few clips into the mdf for holding bits and pieces. Then a well deserved wash and pulled in for a bit of wax.
Post #282878 17th Nov 2013 12:38pm
T1G UP
nice
Post #282879 17th Nov 2013 12:45pm
Likeomg
mcma1 wrote:
do the arch adapters just pop rivet in?
Post #283292 18th Nov 2013 7:39pm
mcma1
They do indeed, plus we bonded all around these aswell.
Post #283293 18th Nov 2013 7:43pm
