![]() | Home > My Defender > X tech.. |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2940 ![]() ![]() |
Thanks,
Not actually sure I am selling it, hard to replace. ![]() Yes we fitted the glass ourselves. |
Mcma1 I sent him a 'pm' suggesting as much. There is also quite a comprehensive 'how to fit' link on Landyglass website.
![]() Treat every day as if it is your last....one day you will be right!! |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Hi Cevapcici,
Did you buy the standard 8700 or the 8700 Evolution? 8700 (no integrated side light) http://www.mobilecentre.co.uk/index.php?ma...cts_id=398 8700 Evolution (integrated side light) http://www.mobilecentre.co.uk/index.php?ma...cts_id=570 The X-tech comes with headlights that feature integrated side lights instead of the completely separate side lights on the non-SVX grille. this requires the 8700 Evolution which has the integrated side light. You can see the subtle differences in the 2 links as the evolution has a little eyebrow type slit above the first glass ball which would be the second plug and operate as a side light. regards Steve =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
cevapcici kid Member Since: 23 May 2014 Location: Melbourne Posts: 6 ![]() ![]() |
Steve,
Thanks for the quick reply! i bought the evolution. Do i have to get some sort of connector that plugs each plug from the car into one plug into the headlight for the first switch setting on my headlight stick to work? |
http://www.mobilecentre.co.uk/index.php?ma..._3_LRG.jpg
there should be a separate wire with the clear plastic covering for the 2nd side light wire as per this pic. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
mmm
there was not. so clearly theyve sent me the wrong lights. grrrrrrrr |
this is the page i bought from;
in the description, are they the correct ones with the side light? http://www.kbcarstuff.com/JW-Speaker-Model...700-ev.htm i assumed this meant that they came with the integrated side light; ECE RHT-compliant high/low beam with front position ECE LHT-compliant high/low beam with front position |
Iv'e just checked the Speaker site so as to not suffer the wrath of opinion over knowledge (which I fully back
![]() The standard 8700 or on the website '8700 HB' is the type without the integrated side light. The 8700 Evolution is with the integrated side light. From your link, they have put the standard light picture but referenced the 8700 Evolution. You have a case to go back to them with. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Decca Member Since: 21 Dec 2019 Location: West Midlands Posts: 4 ![]() ![]() ![]() |
Hi Mcma, do you have any other dashboard pics please? You may have answers to my thought process About what can be done/ art of the possible please? Cheers mate
