Home > For Sale & Wanted > [Wanted] 10P Td5 cylinder head
As it says, need a 10P (don't think the 15P are interchangeable without a lot of fuel pipe faffing about?) cylinder head in good working order.
don't need injectors/cam/top cab framework etc.
Post #279743 5th Nov 2013 5:50pm
TJ101
Shocked That don't sound good,,But if it sorts it Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #279761 5th Nov 2013 6:56pm
I took the head (Which i'd bought a few years back and had sat on the shelf in the garage waiting for a Td5 rebuild, and was assured was AOK Evil or Very Mad ) to be skimmed & pressure tested, as the coolant system kept getting pressurised.
I popped down to the machine shop today, there is a crack between the injector and glowplug hole on cyl #2, and a (major) crack on the valve guide outer bit... the pressure tested it (prior to skimming) and apparently it bubbled like a bubbly thing.
Still, answers my question as to what was up with it.
They did have a 15P head in there that had just been checked and was fine. but I don't think they're interchangeable.
Post #279773 5th Nov 2013 7:35pm
TJ101
Well, at least it answered the question as to why it keep pressurising !! Big Cry California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #279804 5th Nov 2013 8:30pm
For sure it does.
Ah well, such is life. annoying as I've been offered a kind of swap/PX for a G-W for it.... Big Cry but obviously it would need to be working first Laughing
Post #279808 5th Nov 2013 8:40pm
jst
philon will have one, got his number? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #279825 5th Nov 2013 9:17pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello Jim,
I have one which I took off mine because I was using water. I don't think there is such thing as a good TD5 head even the later ones seem to have problems.
I fitted an AMC head, very good quality and has improved on the known issues but they are not cheap.
If you get a good? Used head I can recommend you send it to spaceseal, we use this at work on some very high performance engine castings when they are porous.
I will eventually clean my old one up seal it and rebuild it and put it up for sale, are you in a rush?
Steve
Post #279858 5th Nov 2013 10:11pm
Cheers for the tip Steve.
I'd like to find one in the next week or 2, mainly to get the 90 running again (although I could nail the old head back on just to start it up and drive it about a bit)
Don't think I have James, no.
Post #279949 6th Nov 2013 8:53am
Alas Philion hasn't got one. Sad
Post #279990 6th Nov 2013 11:29am
barbel jim
Don't know if this is any use to you Jim but is the cheapest on the bay Rolling Eyes http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...m3a822c047
Post #279994 6th Nov 2013 11:40am
Cheers jim, already have that saved in my favourites Thumbs Up
Post #280003 6th Nov 2013 12:31pm
jimbob7
Another for you
http://www.ebay.co.uk/itm/LAND-ROVER-TD5-C...1103578463 Pov.spec,ftw. 2006, 110,TD5.
Post #280169 6th Nov 2013 10:10pm
Ooh bit steep on price that one. Shocked
Added: I've got a nice CD jukebox here if anyone wants to do a deal.
Post #280172 6th Nov 2013 10:14pm
