Home > For Sale & Wanted > [Wanted] 10P Td5 cylinder head |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
That don't sound good,,But if it sorts it California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
5th Nov 2013 5:56pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6088 |
I took the head (Which i'd bought a few years back and had sat on the shelf in the garage waiting for a Td5 rebuild, and was assured was AOK ) to be skimmed & pressure tested, as the coolant system kept getting pressurised.
I popped down to the machine shop today, there is a crack between the injector and glowplug hole on cyl #2, and a (major) crack on the valve guide outer bit... the pressure tested it (prior to skimming) and apparently it bubbled like a bubbly thing. Still, answers my question as to what was up with it. They did have a 15P head in there that had just been checked and was fine. but I don't think they're interchangeable. |
5th Nov 2013 6:35pm |
Well, at least it answered the question as to why it keep pressurising !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
5th Nov 2013 7:30pm |
For sure it does.
Ah well, such is life. annoying as I've been offered a kind of swap/PX for a G-W for it.... but obviously it would need to be working first |
5th Nov 2013 7:40pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8002 |
philon will have one, got his number? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Nov 2013 8:17pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Hello Jim,
I have one which I took off mine because I was using water. I don't think there is such thing as a good TD5 head even the later ones seem to have problems. I fitted an AMC head, very good quality and has improved on the known issues but they are not cheap. If you get a good? Used head I can recommend you send it to spaceseal, we use this at work on some very high performance engine castings when they are porous. I will eventually clean my old one up seal it and rebuild it and put it up for sale, are you in a rush? Steve |
5th Nov 2013 9:11pm |
Cheers for the tip Steve.
I'd like to find one in the next week or 2, mainly to get the 90 running again (although I could nail the old head back on just to start it up and drive it about a bit)
Don't think I have James, no. |
6th Nov 2013 7:53am |
Alas Philion hasn't got one.
6th Nov 2013 10:29am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
Don't know if this is any use to you Jim but is the cheapest on the bay http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...m3a822c047
6th Nov 2013 10:40am |
Cheers jim, already have that saved in my favourites
6th Nov 2013 11:31am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Another for you
http://www.ebay.co.uk/itm/LAND-ROVER-TD5-C...1103578463 Pov.spec,ftw. 2006, 110,TD5. |
6th Nov 2013 9:10pm |
Ooh bit steep on price that one.
Added: I've got a nice CD jukebox here if anyone wants to do a deal. |
6th Nov 2013 9:14pm |
