Home > Technical > Defender td5 with a Tdci Dash
D922MAT
United Kingdom 2004 Defender 110 Td5 XS DCPU Loire Blue
Hi every ono im think about putting a tdci bulkhead in to a 2005 td5 defender. A couple of people have told me to use a very late td5 Bulkhead a td5 loom an then fit the dash to this. Has any ono tried this on this. or could advise on what to do Thanks Matthew
Post #278763 2nd Nov 2013 10:50am
DOOFER
I've just got hold of a tdci bulkhead that I'm going to put in my 300tdi. Finger crossed lol
Post #278778 2nd Nov 2013 11:58am
landyman37
Mat me and my son has had a go but are still trying to sort out the dash we gave had plenty of maybes and promises but nothing gas come of it. We have seen a picture of a tdci dash that's had a tdi defender clocks put in it that looks quite cool.
Phil
Post #284401 22nd Nov 2013 8:08pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
See here: http://4x4community.co.za/forum/showthread...=Puma+dash
Local conversion, tdi to Puma dash.
Post #284780 24th Nov 2013 2:25pm
mobilecentre
It is possible but NOT easy especially if you want to retain the tdci instruments as you will need a special interface to get instruments to work correctly as some functions are on CAN.
Post #286358 29th Nov 2013 8:37pm
landyman37
I have tried to get some sort of special interface but all the ones I have spoke to have promised but not come up with the goods. Don't think there are many more left to contact.
Post #293116 25th Dec 2013 3:21pm
Killer90
Site Sponsor
I have a 90 in the workshop ready for the new year which i have got to fit a puma dash into. Ill let you know how it goes Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #293187 26th Dec 2013 10:11am
landyman37
Cheers killer I am stuck with ours at the moment
Phil
Post #293191 26th Dec 2013 10:15am
Killer90
Site Sponsor
Laughing im guessing its not going to be easy but shouldnt be too bad just time consuming. Once the old dash is completly out you need to fix the handlbar type peice to the bulkhead of the landy, once thats done the dash will just screw to the back. Getting the electrics to work shouldnt be a problem for the hazards and elec windows etc, the speedo i am going to use the original and make a panel up to fit behind the standard puma cluster piece Thumbs Up Then ill see what other issues i have Whistle Rolling with laughter CSK Automotive
Post #293196 26th Dec 2013 10:24am
landyman37
Our dash is all in and working apart from the instrument cluster. We are having trouble with the electrics that were CAN fed rev counter engine light glow plug light charge light and temp gauge. As I said in my earlier post we have tried various company's suggested by different people on various forums. They all promised but never came up with the goods. So if you find away around this problem I will be very interested in how.
Also there is the issue with the gear lever we used a disco 2 gearbox took a bit of cutting and welding with the lever to clear the heater. Then we custom made the gearbox tunnel to suit the gear levers.
Phil
Post #293206 26th Dec 2013 11:45am
Killer90
Site Sponsor
Phil how far forward is the dash and the gearsticks ? any photos please.
Im going to get my electricians on the job to see if we can get the dials working Thumbs Up CSK Automotive
Post #293214 26th Dec 2013 1:44pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I'm probably in the minority, but I prefer the Td5 dash to the Tdci one... I like the simplicity and that it isn't so bulky. The controls are all in easy to find, functional places. If it ain't broke and all that.... and I also wouldn't want to lose my flap controls! Wink Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #293424 27th Dec 2013 3:51pm
landyman37
Killer we went for a disco two box so the high an low lever was cable driven sat that next to the gear lever. Also had to re work the front of the seat box due to the gear lever coming right in the front of it.Don't have any measurements just cut fibre glassed made up brackets as we went along then packed it off to the trimmers. As I said just cannot get the clocks to work.
Phil
Post #294048 29th Dec 2013 9:47pm
galvernisednuts
England 1994 Defender 110 300 Tdi SW Santorini Black
Hello just flicking through and thought I'd add my bit
My 300 Tdi has a Tdci full bulkhead and I opted for a disco gearbox
Didn't use the gauges and instead made my own mount for manual gauges and just added a couple of wires
I'll add pics soon
Post #370019 6th Nov 2014 10:45pm
galvernisednuts
Can't seem to add photos?
Find it on Landy zone though
It's been done for over 2 years now
Didn't see the point complicating the dash with ecu stuff on a simple 300 Tdi
Post #370021 6th Nov 2014 10:49pm
