![]() | Home > Technical > Reverse gear |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
What do you mean clicks out? To select its pressure to the left and up and that's all there is to it. To disengage is just the opposite. There is no way that it can be selected by accident either.
My only gripe with the reverse gear as it's gearing is a bit high IMO it's a touch taller than first gear which isn't something I'm keen on. It's okay for reversing at speed (who does that??) but for general maneuvering it's can be a tad annoying because it feels less controllable. Should be the same as 1st imo WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
yeah the lever/linkage itself I've found can make a bit of a plasticy click when disengaging, normally fine if i dip the clutch enough though. think its when your just dragging it out of gear with partial dipped clutch in my experience, otherwise its fine 99.9% of the time Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
I think I know what you mean. Lamborghini spend a lot of money to achieve a click like that.
![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
Both my Td5's do do it... there is a safety catch inside the box to stop you going from 5th to reverse/vica versa |
TD5 is different as reverse position is 6th on a Puma. Craig Rogers
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
It doesnt click on its own accord....just when you pull it out it kind of makes this plasticy clump like its stuck almost.. |
