Home > Puma (Tdci) > Earth for rear lights
Page 2 of 2 <12
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Job done cheers guys the earth wasn't attached Confused
Thumbs Up 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #263811 4th Sep 2013 7:50pm
RickH
So, right ball park, but slight variation....
I have a 2001 TD5 90 that I've just swapped out the indicators front and rear for LED items. Test of hazards showed the expected faster than usual flashing with the omission of that first trailer flash. Solution; fit the adjustable relay that was purchased at the same time. Then it went weird. The flashing is now so quick I can't even replicate when trying to explain over the phone. The vendor suggested checking the earth points.
All incandescent bulbs were working just fine before I got the screwdriver out, all LEDs work fine on indicate and on hazard. Now I see that the offside rear indicator is covered in mud as it appears to be unprotected, would this be a potential source of problems, or should I be looking at the earth situation? I see from the postings above that there's talk of an earth for rear lights on the transfer box, one in the RHS wheel arch and possibly one in the number plate light.
Would that cover possible indicator issues?
Post #277495 28th Oct 2013 1:07pm
tpy
France 2005 Defender 110 Td5 CSW Bonatti Grey
blackwolf wrote:
If you can't find it let me know and I'll dig out the picture again. Won't be till Tuesday though since I'm away from home at present.
Blackwolf, I could use the picture you mentioned to locate the earthing points on my 05 defender. I'm having troubles with my indicators (none of the 6 lights flashes, no hazard warning lights either) since I took the car up a mountain road under heavy snow fall. From what I found on the web, it looks like checking the conditions of my earth points could be a good idea. The electrical diagrams in the Haynes manual mention the existence of 7 points for the td5 but do not indicate where these are. Any clue? Thanks!
Post #315228 11th Mar 2014 12:03pm
Unfortunately I cannot find the diagram I remember. The earth point for the rear lights is in the vicinity of the RH gearbox mount however.
I sounds unlikely that you problem is the simultaneous failure of multiple earth connections since if this happened other things would also have stopped working. Look to your flasher unit first, I suggest.
Post #315259 11th Mar 2014 2:32pm
Aha, found it!
Post #315264 11th Mar 2014 2:59pm
tpy
Great, thanks a lot!
Post #315320 11th Mar 2014 8:19pm
munch90
there is a small (not battery main earth ) earth on the side of transfer box on drivers side
that's the one - pic wasn't there when I started post
Post #315328 11th Mar 2014 8:39pm
Page 2 of 2 <12
