Home > Puma (Tdci) > Earth for rear lights
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Any one tell me if there is a earth that attaches anywhere on the rear of the chassis ?
For the lighting loom ?
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #261207 25th Aug 2013 5:03pm
On pre puma, they bolt onto the bodywork and via the main wiring loom (I can't remember if my Td5 does as well... I think not)
Post #261217 25th Aug 2013 5:52pm
ericvv
On the pre 2013 Puma you can maybe use the black wire of the permanent live wires (purple and black) behind the RH side rear sidepanel. That one here:
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #261219 25th Aug 2013 5:56pm
big steve
Ok cheers looking at my op I don't explain my self well my rear lights and I detractors arnt working nor is my reverse lights so I think I have a earth fault ?
Post #261223 25th Aug 2013 6:06pm
ARC99
Is it both sides that have failed or just one.
The earth wiring diagramme seems to show two for the rear of the vehicle, one each side. The exact location of the earth points are not shown. Don't make old people mad.
Richard
Post #261233 25th Aug 2013 6:53pm
big steve
Both sides yes 2015 2.2 tdci hardtop xs
Post #261236 25th Aug 2013 7:00pm
ARC99
Well I have been out and flung myself under the back end of mine with a torch, I cannot see any earth points that are easily visible. Don't make old people mad.
Richard
Post #261244 25th Aug 2013 7:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Is this link of any use. I doubt if LR made any major changes to earthing points between MY's.
http://www.aulro.com/afvb/technical-chatte...ender.html Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #261251 25th Aug 2013 7:26pm
dgardel
Italy
corrected link Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #261285 25th Aug 2013 8:55pm
big steve
Cheers guys will have a play with the multi meter
Post #261286 25th Aug 2013 9:01pm
dgardel
Italy
Grounds for My07 ON
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #261288 25th Aug 2013 9:12pm
big steve
Mines a truck cab so hope it's not different but Iv also found out today I have no rear lights atall nothing works ?
Any suggestions
Post #262461 30th Aug 2013 6:43pm
Rear lights are earthed in the vicinity of the transfer box. I think that a year or two ago I posted the manual page showing the location.
Post #262516 30th Aug 2013 9:38pm
big steve
Cheers blackwolf hopefully ill find it Thumbs Up 2015 2.2 tdci hardtop xs
Post #262723 31st Aug 2013 7:26pm
If you can't find it let me know and I'll dig out the picture again. Won't be till Tuesday though since I'm away from home at present.
Post #262758 31st Aug 2013 8:56pm
