Home > Puma (Tdci) > Console reflection on r/h/ window
BigWheels
I've noticed that when driving in the dark, my console when back-lit, reflects on the r/h window effectively glaring-out the outer half of my door mirror since the 2 are in line.
Does anybody else have this problem, is there an extension console hood that can be fitted? (No, I don't accept opening the window as an alternative for bad design.)
Why are Defender windows so reflective?
Post #27664 21st Mar 2010 10:43pm
K9F
If you get your windows tinted it gets worse! When I look in my rear view mirror the relection is that good between the front and rear windows that I can see what's heading towards me rather than what's behind me!
If you read it slowly it does make sense! Honest! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27667 21st Mar 2010 10:54pm
mse
I have that problem - i see the car in front in the rear at night! Mike
Post #27671 21st Mar 2010 11:28pm
Eduardo
Same here...
But nothing to do Eduardo
Post #27677 22nd Mar 2010 3:12am
K9F
Eduardo wrote:
Same here...
But nothing to do
Oh yes there is! Whistle Get used to it! Laughing
When I first experienced it I nearly had a brain fart trying to figure out what was going on! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27683 22nd Mar 2010 7:31am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I was initially quite surprised to see someone apparently coming up behind me with a closing speed of 80mph Shocked
The best thing to do for the rear window is obscure it with child seats, cargo barriers and window guards. Then you pretty much can't see anything in either direction Whistle
I've never noticed my instrument binnacle reflected in the side window though. Try turning your lights off and using the Force Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #27692 22nd Mar 2010 9:59am
Grockle
Re: Console reflection on r/h/ window
Why are Defender windows so reflective?[/quote]
could it be because they are made of glass Smile 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #27695 22nd Mar 2010 10:21am
110SEB
Never noticed this one.
Buying a Mondeo could be a permanent fix?
Blinkers?
Post #27698 22nd Mar 2010 10:50am
K9F
Exorcist Abilities.
I can't really understand why this is an issue! Just rotate your head a complete 180 degrees and face backwards when driving forwards at night - problem solved! Anyone can do that! Can't they?????
Rolling with laughter Rolling with laughter
Post #27699 22nd Mar 2010 11:05am
Eduardo
Laughing Laughing
As one teacher said me sometime, "If the problem cannot be solved is not a problem anymore: it is a fact. If the problem can be solved also is not a problem: is just a thing to do".
I like the solution of rotate the head in 180° but I believe that require some practice...
Cheers! Eduardo
Post #27705 22nd Mar 2010 11:57am
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
All windows are reflective, it just happens that Deefer windows are also almost completely vertical (upright), rather than curved like most modern designs....
Post #27788 22nd Mar 2010 11:27pm
K9F
That's why when they get hit with a stone there are no 'glancing blows' but you inevitably need a replacement. I've had the misfortune of two windscreen replacements in a very short period of time.
Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27793 23rd Mar 2010 7:46am
Eduardo
Yeah,
Also the windscreen works as a insect attractor...
In other cars with more curved and horizontal windscreens the insect tends to fly up and do not impact directly as in the Defender.
Cheers Eduardo
Post #27823 23rd Mar 2010 12:24pm
