Home > Puma (Tdci) > Console reflection on r/h/ window |
If you get your windows tinted it gets worse! When I look in my rear view mirror the relection is that good between the front and rear windows that I can see what's heading towards me rather than what's behind me!
If you read it slowly it does make sense! Honest! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st Mar 2010 10:54pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
I have that problem - i see the car in front in the rear at night! Mike |
21st Mar 2010 11:28pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Same here...
But nothing to do Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
22nd Mar 2010 3:12am |
Oh yes there is! Get used to it! When I first experienced it I nearly had a brain fart trying to figure out what was going on! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Mar 2010 7:31am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I was initially quite surprised to see someone apparently coming up behind me with a closing speed of 80mph
The best thing to do for the rear window is obscure it with child seats, cargo barriers and window guards. Then you pretty much can't see anything in either direction I've never noticed my instrument binnacle reflected in the side window though. Try turning your lights off and using the Force One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
22nd Mar 2010 9:59am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Why are Defender windows so reflective?[/quote]
could it be because they are made of glass 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
22nd Mar 2010 10:21am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Never noticed this one.
Buying a Mondeo could be a permanent fix? Blinkers? |
22nd Mar 2010 10:50am |
I can't really understand why this is an issue! Just rotate your head a complete 180 degrees and face backwards when driving forwards at night - problem solved! Anyone can do that! Can't they?????
22nd Mar 2010 11:05am |
As one teacher said me sometime, "If the problem cannot be solved is not a problem anymore: it is a fact. If the problem can be solved also is not a problem: is just a thing to do". I like the solution of rotate the head in 180° but I believe that require some practice... Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
22nd Mar 2010 11:57am |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 |
All windows are reflective, it just happens that Deefer windows are also almost completely vertical (upright), rather than curved like most modern designs.... |
22nd Mar 2010 11:27pm |
That's why when they get hit with a stone there are no 'glancing blows' but you inevitably need a replacement. I've had the misfortune of two windscreen replacements in a very short period of time. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Mar 2010 7:46am |
Yeah,
Also the windscreen works as a insect attractor... In other cars with more curved and horizontal windscreens the insect tends to fly up and do not impact directly as in the Defender. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
23rd Mar 2010 12:24pm |
