Home > In Car Electronics > The definitive Defender ICE thread |
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 |
OK, thanks.
than I will first start with the upgrade of the head unit and speakers. May be than the sound is already good enough for me. If not, I can always place this sub woofer. |
24th Oct 2013 11:58am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Got some gubbins to throw in
Click image to enlarge |
24th Oct 2013 1:00pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20446 |
mees - Best way to go. you might find it lacking in bass a little of which if you do then a Sub should be your route to take after that.
Tiger - Nice little lot you've got there! what have you got in there? No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Oct 2013 4:11pm |
That will be
1 Kenwood KFC-S503P 13cm component speakers http://www.justkenwood.co.uk/car-audio.aspx/kfc-s503p-speakers 1 Kenwood KAC-6405 four channel power amplfier http://www.justkenwood.co.uk/car-audio.aspx/kac-6405-amplifier 1 Kenwood KFC-S6974 6x9 speakers (pair) http://www.justkenwood.co.uk/car-audio.aspx/kfc-s6974-speakers 1 Kenwood KFC-E1064 10cm speakers (pair) http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1064-speakers 1 Kenwood KSC-SW11 active subwoofer http://www.justkenwood.co.uk/car-audio.aspx/ksc-sw11-speaker |
24th Oct 2013 4:20pm |
That'll keep you busy then. if you want a hand let me know, although I am sure you are more than capable yourself. No Guts, No Glory.
24th Oct 2013 4:24pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
The 13cm components 'Up Front ?'
24th Oct 2013 4:38pm |
Yep, should squeeze them in
24th Oct 2013 4:46pm |
I'm sure you'll probably have already read it but this might be of interest for fitting componants http://www.defender2.net/forum/topic23102.html
The only problem encountered was the cover in passenger footwell, over the wiper motor. It had to be persuaded out so the speaker ring would sit flat. Feel free to PM me should the need arise, but it is relatively straight forward. Good luck and............... Pictures |
24th Oct 2013 4:59pm |
Feeling like a good whistle there Jim.
24th Oct 2013 5:42pm |
Well I've just offered up the active sub to the back of the cubby box and it's a bloody perfect fit.
Looks like it was made for a Defender cubby box, super happy! May take a photo later. |
24th Oct 2013 6:17pm |
Excellent, need photos though. No Guts, No Glory.
24th Oct 2013 6:20pm |
Click image to enlarge Not the best but you get the idea |
24th Oct 2013 6:26pm |
It's dead flush to the sides to the mm
24th Oct 2013 6:27pm |
Does look good doesn't it. be careful with the fixings though.... Probably best to use some small blunts and nuts and not screws or they'll stick out the other side. No Guts, No Glory.
24th Oct 2013 6:38pm |
