Home > Maintenance & Modifications > Low budget, low tech, higher torque?
BigWheels
How greatly would something as simple as an air filter upgrade, to a brand such as Green improve engine performance & response.
What I'm after is getting to max torque rpm faster. More torque overall would be nice, but remapping is too OTT a consideration, so I'm looking for low tech solutions or just getting to the OE max by easier engine speed increase better. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #275721 21st Oct 2013 10:05pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi there,
Have a look here......http://www.defender2.net/forum/topic21125.html?highlight=air+filter+test
Think I will stay with standard! BM52
Post #275722 21st Oct 2013 10:08pm
TJ101
From memory,, Pete at Bas tried various so called performance air filters,, with little gained if any California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #275723 21st Oct 2013 10:09pm
IMO a waste of time and no gain to be had in any way really. OE filter is tried and tested so I have no reason to ever change. Similar to the snorkel issue but in that case there it is more justified with a filter you are pretty much swapping like for like but with a snorkel it serves a few purposes. KEEP CALM AND Drill ON
Post #275730 21st Oct 2013 10:40pm
Forgot to mention, how about putting a straight through centre silencer? That will give you a performance increase KEEP CALM AND Drill ON
Post #275731 21st Oct 2013 10:42pm
dgardel
Italy
bm52 wrote:
Hi there,
with more engine wear, the OEM has the best trap capacity for very very tiny sand Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #275738 22nd Oct 2013 5:04am
TJ101
TJ101 wrote:
From memory,,
Very Happy So not completely gone to pot yet then Rolling with laughter
But snorkel's.. as a RAI work well when in dusty conditions,again with the std filter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #275749 22nd Oct 2013 6:53am
an exhaust upgrade would help
Post #275750 22nd Oct 2013 6:56am
