![]() | Home > Maintenance & Modifications > Low budget, low tech, higher torque? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Hi there,
Have a look here......http://www.defender2.net/forum/topic21125.html?highlight=air+filter+test Think I will stay with standard! BM52 |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
From memory,, Pete at Bas tried various so called performance air filters,, with little gained if any California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
IMO a waste of time and no gain to be had in any way really. OE filter is tried and tested so I have no reason to ever change. Similar to the snorkel issue but in that case there it is more justified with a filter you are pretty much swapping like for like but with a snorkel it serves a few purposes. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Forgot to mention, how about putting a straight through centre silencer? That will give you a performance increase WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
with more engine wear, the OEM has the best trap capacity for very very tiny sand Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() ![]() But snorkel's.. as a RAI work well when in dusty conditions,again with the std filter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
an exhaust upgrade would help
