Home > Puma (Tdci) > Puma help needed
Puma help needed
If anyone can help. A friend of mine in the next farm has a new-ish puma 2.2
He's getting a "whooshing" noise when he accelerates, and his sons scanguage shows P0101.
I've not had chance to go over and have a gander at it yet, stuck on lates tonight, but has anyone got a clue as to what it might be?
I suggested checking the air pipes for one that might have come off. googling that code shows MAF faults, but what would cause the whooshing noise?
cheers all.
Post #275601 21st Oct 2013 6:25pm
vodonos
Slovenia 2012 Defender 110 Puma 2.2 SW Sumatra Black
Mass or Volume Air flow sensor problems
Best ragards
bm BO�TJAN
SLOVENIA
Cerknica lake
90 td5 2000
110 2,2 2012
Post #275618 21st Oct 2013 7:17pm
K9F
Mass or Volume Air Flow "A" Circuit Range/Performance
Split intercooler hose perhaps or insecure jubilee clip? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #275626 21st Oct 2013 7:33pm
bell-auto-services
It could be this issue which is getting more common. Or the hose could have come off at the turbo.
Post #275635 21st Oct 2013 7:52pm
Thanks all. gives me something to look at.
Pete... which hose is this one?? I seem to recall a thread on it some time back, but can't remember which one it was.
cheers
Post #275643 21st Oct 2013 8:27pm
ameliadunlop
We had exactly the same in our new Puma at the weekend. Ours was a split high pressure turbo pipe that had been rubbing on the alternator pulley. Apparently its a known fault with the new ones. Luckily ours is under warranty and the guy who came out from Land Rover Assistance said they fit the replacement in a slightly better way to avoid it happening again. I'm afraid that's as technical as I get but hope that helps. 2015 Defender 90 HT Corris Grey - Bowler Stage 2
2016 Discovery 4 SDV6 Graphite Santorini Black
Post #275645 21st Oct 2013 8:34pm
K9F
Would you not perhaps expect an accompanying P1102 Mass Air Flow Sensor In Range But Lower Than Expected and a MIL light perhaps with such a fault dependant on severity of leak of course or does the P0101 override it? Still surprised no MIL light though.
Diesel Jim....this thread..... Thumbs Up Thumbs Up
http://www.defender2.net/forum/topic20804.html?highlight=rubbing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #275662 21st Oct 2013 8:56pm
ameliadunlop
Should have said Embarassed we had MIL light although a good few miles after the hissing stared and when accelerating up a hill. Only code read was P0101. Now I really must bow out to those with far more knowledge! Razz Bow down 2015 Defender 90 HT Corris Grey - Bowler Stage 2
Post #275670 21st Oct 2013 9:08pm
bell-auto-services
Thanks for the link K9. You beat me to it hehe.
Post #275680 21st Oct 2013 9:22pm
Thanks all. yes, it was the pipe rubbed through. Thumbs Up
Post #275746 22nd Oct 2013 7:44am
bell-auto-services
Thumbs Up
Post #275756 22nd Oct 2013 8:31am
He's got a pipe coming from the local dealers, who can't get one until Friday! Rolling Eyes
You'd have though with this pipe being such a problem, they'd have them stacked on the shelves.
Post #275888 22nd Oct 2013 7:36pm
bell-auto-services
The problem is is that the new pipe is also a problem and I bet they can't meet build demand due to the failures of them. They have made the pipe a second time and its worse than the first hehe.
Post #275891 22nd Oct 2013 7:38pm
