Home > Technical > Puma 90 Battery Charger Advice Please
Page 2 of 2 <12
Glynparry25
CTEK with towing connector gets my big thumbs up Thumbs Up
No electrics?
The CTEK comes with the 'quick connect as part of the package (RH side of picture)- no cost:
Or, buy the panel adaptor:
Or, cigarette adaptor:
Glyn Dog Sheep
Post #274242 16th Oct 2013 1:11pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I bought a decent solar panel charger. I stuck on dash of 90 and it kept it charged no matter how infrequently I used the Defender - even through British winters.
This saved issue of running leads out to 90 when not in use.
Post #274246 16th Oct 2013 1:35pm
Snapper
If you use a solar panel charger... Am I correct that if you plug it in to the cigarette adaptor it will still charge the battery while all the electric are off and the vehicle is all locked up on a Puma 2.2 Defender?
Or ro you need to run some extra wires to the motor?
Post #274331 16th Oct 2013 7:08pm
JSG
No, it wouldn't as the standard socket in the dash is only 'live' and connected to the battery when the ignition key is in position one.
You'd need to run another permanently live socket for it. John
2011 Tdci 110 CSW XS
Post #274554 17th Oct 2013 2:35pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Sorry if a daft question but could you put an Anderson connector onto the end of a ctek cable to charge ?
Post #274555 17th Oct 2013 2:58pm
JSG
Yes, no reason why not with the right cable connection. John
Post #274773 18th Oct 2013 11:24am
Page 2 of 2 <12
