Home > Technical > Puma 90 Battery Charger Advice Please |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 661 |
I bought a decent solar panel charger. I stuck on dash of 90 and it kept it charged no matter how infrequently I used the Defender - even through British winters.
This saved issue of running leads out to 90 when not in use. |
16th Oct 2013 1:35pm |
Snapper Member Since: 14 Oct 2013 Location: Wales Posts: 4 |
If you use a solar panel charger... Am I correct that if you plug it in to the cigarette adaptor it will still charge the battery while all the electric are off and the vehicle is all locked up on a Puma 2.2 Defender?
Or ro you need to run some extra wires to the motor? |
16th Oct 2013 7:08pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
No, it wouldn't as the standard socket in the dash is only 'live' and connected to the battery when the ignition key is in position one.
You'd need to run another permanently live socket for it. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
17th Oct 2013 2:35pm |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 |
Sorry if a daft question but could you put an Anderson connector onto the end of a ctek cable to charge ?
17th Oct 2013 2:58pm |
Yes, no reason why not with the right cable connection. John
18th Oct 2013 11:24am |
