Home > Technical > Puma 90 Battery Charger Advice Please
Snapper
I have a Puma 2.2 HardTop and it does not get a lot of use at the moment, Few short journeys a week. As a result the alarm sounds when starting it up. I note that when the 90 has a good run I don't suffer this problem.
I therefore think that the Battery could do with a boost every now and then especially now we are heading into the cold season.
Could anyone recommend a good trickle charger or charge that can be used while leaving the battery fully connected to the vehicles electronics?
The battery installed is a '12v 90amp 800 A EN' wet cell battery.
All advice welcome
Post #273759 14th Oct 2013 6:14pm
Cheshire110
halfords or equivalent will sell a fairly cheap, basic but does-the-job one..
i have an RAC one which always works fine, most batt chargers will have a trickle charge function.
i used to leave the charger itself in the seat box with the battery with just the plug hanging out and an extension lead into the car when i needed it Cheers, David
Post #273782 14th Oct 2013 6:54pm
landy andy
Ctech chargers Thumbs Up Thumbs Up
Andy
Post #273838 14th Oct 2013 8:04pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
On offer in Aldi this week coming.
Post #273840 14th Oct 2013 8:06pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
There are loads of them to choose from and I've certainly gone through loads, but got a ctekthrough a group buy on Disco3 forum and a towing electrics adapter off Martin and I don't know how I coped before.
Ctek and the adapter all the way for me from now on. I'm so pleased I'm about to buy another 3. Thumbs Up
Post #273865 14th Oct 2013 9:05pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Ctek for me too. Works really well, simple to use - just connect up and leave. Will tell you if battery is u/s. I bought a small capacity one to keep the batteries in tip top condition when I leave the vehicle for long periods. Just left it on for 4 weeks whilst I was away and let it cycle through all the modes
Post #273912 14th Oct 2013 10:07pm
Norm4n
Are there any other quick attachment alternatives to the following from the Disco3 forum which uses the towing electrics? (i don't have towing electrics!)
http://www.defender2.net/forum/topic20342.html?highlight=charger
Like others have said access to our batteries isn't that easy, especially if you suddenly need to dash out and the seats in bits......
Post #274208 16th Oct 2013 10:34am
Cheshire110
http://www.mobilecentre.co.uk/index.php?ma...cts_id=620
Give this a look Cheers, David
Post #274211 16th Oct 2013 11:03am
Norm4n
Thanks, have you used this?
Post #274216 16th Oct 2013 11:28am
Cheshire110
No but I saw from this thread that 76MV uses them - look good on his
http://www.defender2.net/forum/topic21535.html Cheers, David
Post #274217 16th Oct 2013 11:32am
there's a ctek group buy on the forum ... do a search
Post #274218 16th Oct 2013 11:32am
Norm4n
Thanks
Post #274234 16th Oct 2013 12:23pm
Cheshire110
Sorry?! I said I'd not used it and pointed you in the direction of someone that has. Cheers, David
Post #274235 16th Oct 2013 12:25pm
Martin
Site Admin
Ctek charger group buy on DISCO3 (open to Defender2 members too):
http://www.disco3.co.uk/forum/topic101098.html?highlight=ctek
Towing electrics adapter (12S or 13pin):
http://www.disco3.co.uk/shop/index.php?act...oductId=45
Modification to CTEK to make it non latching (in case you forget and drive away with it attached...):
http://www.disco3.co.uk/wiki/Remove_lock_button_from_CTEK_plug  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #274236 16th Oct 2013 12:28pm
Martin
Site Admin
3 adapters too? Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #274237 16th Oct 2013 12:32pm
