Home > Technical > Rear Door Rattle |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Probably the striker plate I'd imagine, give it a bit of a tinker and see what difference it makes if any. I doubt the seal will make much difference as it is still isolating metal on metal contact whatever condition it is. The only points of contact are the hinges which are permanent and solid (or should be!) check to see if there is any door movement anyway. (Worth doing)
Other than the the most likely culprit IMO will be the striker plate as you say or the lock mechanism. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
17th Oct 2013 10:40pm |
CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135 |
Thanks, will have a tinker with the striker plate tomorrow, and see what happens
17th Oct 2013 10:50pm |
Mine rattled and it ended up being the wheel carrier that had split in the bottom corners and the metal was creaking together when the wheel moved side to side. Drop the spare off and look up from the underneath of the carrier
17th Oct 2013 10:54pm |
