![]() | Home > In Car Electronics > The definitive Defender ICE thread |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
They are the KFC-ST30s ... wasn't that impressed when sitting on the drive playing the radio but went out on a drive today with some rocking' toons and sounded great - very impressive soundstage overall up front rather than just to my toes - having the high frequencies on top of the dash does make a difference ... and I haven't even wired the sub in yet ! ![]() Sub on back of cubby box waiting to go back in ![]() ![]() Click image to enlarge Jon |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20641 ![]() ![]() |
Will look good.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Dave H Member Since: 18 Aug 2013 Location: Bexley Posts: 28 ![]() ![]() ![]() |
Thanks for the advice guys, I'll keep a lookout for a pair of K2's and give it a go!
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Blackwolf, seems a logical choice to include DAB. I have not used the Pioneer you mention, but the specs good. My only negative is the display. it looks a bit funky for me. I am an Alpine man first but Pioneer would be my second choice. A similar alternative (and my choice) would be http://www.caraudiocentre.co.uk/product_m-...-27582.htm . It shares a similar spec sheet, but will light up green with a simple display.
I think you may just be unlucky with your Kenwood. We all have our preferred brands, and I think the difference in build quality between 'named' brands is negligible. I would have no issue with mid range gear from Alpine, Pioneer, Kenwood, JVC, or Sony. I would avoid all Budget names and cheap 'named' stuff. Its generally cheap for a reason. |
Sorry to hear Blackwolf, what model was it you had? I've had the odd niggle with mine on the rare occasion turning off and back on. All be it very rarely.
Main issue I've had is the removable face plate connection acting up messing the whole thing around? I assume yours is fixed though? There is a possibility there is a short somewhere most like on the speaker wires, and it could be a protected mode. I think it's highly unlikely though. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
What about this?
http://www.caraudiodirect.co.uk/alp-cde136...t-dab.html Russell 2011MY 110 XS USW Black |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17618 ![]() ![]() ![]() |
Steve, it was the KDC-6051U .
Kenwood has just rocket up in my estimation though, since I emailed the customer relations department on Monday to tell my sorry tale and ask if there was anything I could try to reset the unit (really just to have a polite moan since the unit isn't that old - I bought the unit in Sept 2012 so it is one year and one month old, so indisputably out of warranty!). Yesteday evening I had an reply from Kenwood offering to look at it under warranty despite there being no obligation to do so, so well done Kenwood! ![]() ![]() In the meantime however, after a day of driving with no music and consequently being forced to listen to all the knocks, squeaks, bangs, rattles, and other worrying noises I usually drown out I could stand it no longer so fitted the Pioneer DEH-X8500DAB. First impressions are very good. It has some features that score over the Kenwood, and some where the KW scores, but overall I am pleased. The front panel aesthetics and display appear to have been designed by a frustrated Ninja (which is not quite my cup-of-tea) but the controls are easier to operate than the KW, especially in a vehicle which bounces a fair bit. The unit has a more robust feel to it as well. Next challenge will be to find and fit a fit a DAB aerial, which isn't straighforward without obstructing my full-length Patriot rack. All the usuall offerings seem either to be glass mount (which I don't really want for various reason, not least the fact that they don't work very well) or are roof mount using the roof as a ground plane. What I really need is one with an artifical ground plane , but I don't seem to be able to find one. Does anyone know of a DAB aerial with an artifical ground plane? EDIT: I don't actually see why a CB antenna cut down to 315mm mounted on an artifial ground plane wouldn't work. Might try that first. |
Anything in here ? http://www.dabonwheels.co.uk/DAB_car_aerials.html
Thinking I will need to replace my inside glass mount one as reception is quite poor - combination FM/DAB seems the main option ... let us know what you go for and how you get on ... Jon |
Good to hear, can you not get an Antenna with FM and DAB that will mount on the rack it's self? That would be the easiest option IMO.
If you need to earth it just take a wire down with the antenna wire and earth in a suitable location. Or perhaps something could be done by replacing the standard aerial in that position, I personally I don't have DAB or use radio at all as I'm not a big fan if I'm honest. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
That is as good a selection of DAB aerials as I have seen on any vendor's website but all the body mount or mag mount ones still rely on the roof for the ground plane. This means for optimum reception the aerial needs to be mounted as centrally as possible on the roof, which is not great with a rack.
To solve this problem with a CB aerial I bought an AGP from 4x4cb.com (see here for more info) and (with my limited knowledge of antenna theory) I don't see why a plain whip of the appropriate length, which I think is 315mm for DAB on the 226MHz band, mounted on one of these, shoudln't work. We have antenna boffins here at work so I'll see if they have any suggestions. |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 ![]() ![]() |
Glad to hear that kenwood proactively did the right thing. Just so you are aware, there is an EU directive that provides a 2 year guarantee for all consumers goods sold. So as in you case, the unit stops with no visible damage/misuse the manufacturer would be obliged to repair or replace. You have to report it within two months of finding the fault and within 2 years of purchase. Also in the UK there is a 6 year sale of goods act the enables you to get a partial refund or full repair upto six years, again if there is no obvious misuse. |
Didn't know that, useful to know!
Blackwolf - please let us know how you get on with the aerial. I think I understand the principles but it is one thing that is holding back the inevitable switch to DAB. Some forum users seem to get on dandy with the stick on jobs others have used the FM aerial converters its all a bit confusing and has the potential to get expensive when some of those aerials are touching £100
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 ![]() ![]() ![]() |
I want to upgrade the stereo with the following components:
Alpine CDE173BT Focal 100KRS front Focal PC100 rear Will this already be a major improvement, or do I also need to fit an active subwoofer, such as the Focal Ibus 2.0? The power feed for the Focal subwoofer is it coming from the ISO connection? Or do I need to use a separate positive wire directly from the battery? |
