Home > In Car Electronics > The definitive Defender ICE thread
Page 42 of 71 <123 ... 414243 ... 697071>
Looking forward to driving in the dark soon when it gets darker at night so I can have this on
Don't think I put any photos up when I did it earlier this year. Con be constant on or sound activated (the el wire) KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #268528 22nd Sep 2013 11:16am
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Been a busy couple of months at work so not much time to move on with the double-din head unit install ... until today Very Happy
After a bit of foraging and haggling at the LRO Peterborough show my £5 bargain dash and neat anodized aluminum custom-cut plate from Phil at Raptor arrived ... And it looks neat !!
Have a week off soon so will complete the install along with the tweeters and sub - then it's off to Chris at CSK for some underbody love and a few sheets of dynamat for the roof ... assuming I can stop the bloody sunroof leak at the same time !
Post #271073 2nd Oct 2013 9:31pm
That's gonna look trick mate. Thumbs Up KEEP CALM AND Drill ON
Post #271083 2nd Oct 2013 10:10pm
theorangebandit
big fan of that mate looks very rugged and industrial will suit the defender perfectly
Post #271086 2nd Oct 2013 10:27pm
kirk
United Arab Emirates 2009 Defender 110 Puma 2.4 SW Blenheim Silver
HI All,
A professional is installing a system inclusive of dynamat this week.
Just a question about subwoofer location...
Has anyone placed a passive subwoofer in a location other than the centre cubbie? I hate to loose the cup holders and the storage. I have seen a few images in this thread of alternative locations (cargo area, top of wheel well). I also see many folks are using an underseat sub, but I would rather stay away from that.
Cheers,
Kirk
Post #271561 5th Oct 2013 8:51am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
What about the seat box with the speakers ports pointing into the footwells
Post #271588 5th Oct 2013 11:03am
Sealing would be possible but difficult, yes it's ported but ideally the rest needs to be completely sealed or you'll end up with a sub in free air use.
Can't imagine it'd be that nice to practically sit on top of it and also there will be little air movement where the gap is so little,.
Using a cubby it is possible to have space and a sub with careful planning but you will need to be handy to design and make it yourself. KEEP CALM AND Drill ON
Post #271591 5th Oct 2013 11:31am
mk1collector
I still prefer fully sealed sub boxes, they are so much easier to get right and although they aren't as powerful I feel it's easier to get a crisp punchy bass
Post #271592 5th Oct 2013 11:34am
barbel jim
Another vote for sealed enclosures -SQ is much better and stops that farty bass. Also preffer small subs as they can recover and hit the next beat, not blur. Find multiples work better Whistle
Post #271681 5th Oct 2013 6:31pm
No no Jim, small subs in multiples AND bigger subs also in multiples. Can't beat that! Rolling with laughter KEEP CALM AND Drill ON
Post #271684 5th Oct 2013 6:38pm
jont
Managed to get a few more bits done today Very Happy
Spliced the tweeter wiring in to the loom...
Fitted the cage into the new dash frame...
Moved over the switches from the old silver XS dash...
All switches connected and fitted...
Tweeters in place...
Fired it up and all works Thumbs Up
Just the sub to wire up now - have fitted to back of the cubby box !
Post #271685 5th Oct 2013 6:39pm
Dave H
United Kingdom 2009 Defender 90 Puma 2.4 HT Zermatt Silver
Focal speakers
Hi guys, I have spent the last three weekends dynamating my puma hardtop from top to bottom and would appreciate some advice on speaker selection.
I have so far installed a focal bus 8" powered sub on the bulk head behind the passenger seat and a focal FPP 4100 four channel amp behind the drivers seat. The head unit is a Sony DSX-S300BTX (in there when I bought the truck) and I have fitted a pair of Focal PC 100's to the rear, front speakers still standard and not powered through the amp.
My thoughts were to fit a pair of Focal K2 power 6.5" components to the rear and move the PC 100's to the front with the K2's tweeters replacing the the ones in the top of the dash but a mate of mine said this is not a good idea as the tweeters need to be with or close to the midrange speaker at the back?
Any ideas on the best Focal speaker set up? I didn't really want to cut the dash around to fit the 6.5's up front if I could avoid it.
Any ideas would be appreciated
Dave
Post #272883 11th Oct 2013 9:52am
Dave - is he an ICE expert? Laughing I would give it a go and see what it sound like, if you like how it sounds then sorted. So long as the electrical side such as power input and so on is correctly matched which I am sure you've hot correct just play around with it and see what it sound like to you. Just loosely fit if need be to test. KEEP CALM AND Drill ON
Post #272888 11th Oct 2013 10:19am
Not seen those before, Kenwood not so long ago didn't do very well on the Tweeter side of things, had none for sale.
How do they sound? Thumbs Up KEEP CALM AND Drill ON
Post #272892 11th Oct 2013 10:33am
barbel jim
Re: Focal speakers
Technically your Mate is correct. Just don't wire the crossover in at the back, wire it in up front then the fronts will work correct and the 6.5 will provide plenty of mid range Whistle wiring the pc100 after the crossover should then mean it will only act as the woofer for the tweeters and thus sound correct.
Post #272923 11th Oct 2013 12:50pm
