Home > Td5 > Help! Engine cuts out at full throttle |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
Today I received the new injector harness. Thanks Simon!
Replacement of the harness was quite simple. No problems at all. The female connetor to the harness was full of oil so I was convinced that we found the promblem. A vast amount cleaning spray was used to wash away the oil. In spite of the amount of oil at the harness plug by the engine I have not seen any oil at the ECU plug. But it got a dose of spray anyhow. The engine started fine and I let it warm up while I fitted engine covers etc. Then I fully depressed the accelartor. And the engine dies. Same as Before. No differance at all. I give up... Hans |
1st Oct 2013 7:01pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Feel for you fella
1st Oct 2013 7:12pm |
Thanks Tiger...
Hans |
1st Oct 2013 7:24pm |
Yes, you are probably right. And the harness and crank sensor also needed replacement so it was not in vain.
I have tried to borrow an ECU from members of the Swedish LR Club but so far no luck. How much is a new one in UK? Hans |
1st Oct 2013 9:49pm |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
Don't know about new but second hand ones seem to go for about £300 so c.Kr 3,000. 2003 Td5 110 Hardtop
Now a 2013 110 USW too. |
2nd Oct 2013 7:15am |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
2nd Oct 2013 3:14pm |
Used ECU purchased on eBay. Awaiting delivery. Really hope that this is the answer. Will keep you posted.
Hans |
13th Oct 2013 7:36pm |
Good luck Hans.
Wiser people than me might be along soon, but i don't know if it's plug and play. It might be worth checking if it needs synchronising with the immobiliser or if there are any other matters to consider. The codes stamped on your injectors might need entering into the ECU for best performance (using a Nanocom or similar) but it's not essential. Pretty good price though! Simon 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
13th Oct 2013 7:48pm |
From what I understand the ECU needs to be syncronised with the injectors. One guy from the Swedish LR Club will help me with that as I do not have the knowledge nor the equipment.
Besides the ECU I also bought from the same guy a fuel pump, throttle assy and MAF sensor. Might come in handy... And thank you Simon for the lead! Any progress with your Defender? Hans |
13th Oct 2013 9:32pm |
Skye_Rover Member Since: 29 Aug 2013 Location: Skye Posts: 85 |
I have got a 90 TD5 on my books with one of these (amongst many other) faults, but it doesn't lead to the problem that Hans is seeing. The thing has been running around for the last 3 years on 4 cylinders (No.5 injector has failed in some way, but I have not been "allowed" to fix it , as it runs just fine for the owner!!!) but still has the grunt to climb up to 4000rpm under load without cutting out. Because the injector is failed in a "closed" state, no fuel is dribbled to that cylinder, so free-accel smoke numbers for the MoT are just fine. Roads? Where we're going, we don't need roads. |
13th Oct 2013 11:00pm |
It has spent the last few weeks in the hands of IRB Developments and is now there awaiting the arrival of a man with an oscilloscope! 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
14th Oct 2013 8:18am |
Waiting for the ECU (and other parts) to arrive from UK I changed the fuel filter. The old filter did not contain any signs of water or any other contamination. New filter fitted and started fine. Let it idle for a while to get rid of any air. Gave it full throttle and it died immediately. Same as before.
Hans |
17th Oct 2013 9:08pm |
Now she runs well again!
Tonight the guy from the Swedish LR Club came around to sychronise the new ECU. Everything went quite well and now the engine runs well again. He took the old ECU with him to see if it is repairable. A big thanks to Simon and all the rest of you who have been so helpful in order to get my Defender to run again! Regards/Hans |
23rd Nov 2013 11:19pm |
Hooray! Very pleased to hear of your success. 2003 Td5 110 Hardtop
24th Nov 2013 1:27am |
