Home > Maintenance & Modifications > installation of recaro's
Likeomg
Hi guys, little bit stumped, got a set of recaro sportster's,
also purchased 'tune my defender' seat rails... i have no idea what im doing, also the seat rails powder coat puts land rover's paint department to shame,
as seen here are the rails, the problem is acessing the bolts to righten them down...
any one got photos or tips? i.e. removing the base and doing something...? ive removed the bases to see but still no help.
Post #251711 16th Jul 2013 4:43pm
Photo isn't working....
Does the seat still move back or forward like standard? If so you have to have it back to access the front two bolts and forward to access the two at the rear. Hard to explain without a photo but I am assuming this is what you mean?
If the seat is static then there will no doubt be a way of accessing from the top somehow? NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #251713 16th Jul 2013 4:52pm
Likeomg
so completly take the whole set up from ontop of the seat boxes, assemble then bolt back together like that?
here's a pic, seat base is still in place but even with it removed, the frame still gets in the way, might completely removed the frame from the seat box but then i dont think it will go back together (have to check how its bolted inside the seat box...
Post #251714 16th Jul 2013 4:54pm
Likeomg
hmm
Post #251720 16th Jul 2013 5:13pm
Remove the seat and seat frame and then re-assemble. The bolts are captive nuts in the seatboxes so there is nothing underneath all done from the top.
Thumbs Up
You might find you have to take the frame out fix to the seat then put the lot in together and bolt down. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #251723 16th Jul 2013 5:15pm
pjb
Sorry if this is stating the obvious but normally you bolt the runners to the seat, and then more seat forward / backwards to bolt to the seat box - should be simple. Obviously I'm missing something Neutral 2020 P300 HSE
Post #251724 16th Jul 2013 5:17pm
Likeomg
getting at the bolts is quite interesting, the adapters imo are a terrible design but they were the only ones available, nothing lines up even to a half acceptable measure so its a lot of faffing, you have to install 1 bolt then 3 with the runner at a 30 degree angle only tightening a small amount, then the rear, 2, then back to the front boa bla bla... its a pig.
Post #251742 16th Jul 2013 7:35pm
Martin
Site Admin
Something to take up with the supplier of the adapter then.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #251748 16th Jul 2013 8:30pm
Likeomg
The email is sent, with photos, the finish for one is not acceptable, be interesting to hear there side
Post #251750 16th Jul 2013 8:34pm
Likeomg
Thumbs Up
Post #251759 16th Jul 2013 9:07pm
T1G UP
any news?
Post #270087 29th Sep 2013 10:34am
Likeomg
sent me another set out... not that impressed with the quality but i couldn't wait for the alive ones to be made so these were my only option.
Post #270146 29th Sep 2013 3:45pm
T1G UP
so the recaro ones aren't available?
Post #270180 29th Sep 2013 5:50pm
Likeomg
ask gary @ alive, when we spoke they weren't seem to remember him emailing me to say he had some if it wasn't too late... which it was Sad
Post #270751 1st Oct 2013 7:10pm
hamtheman
Ireland 2004 Defender 90 Td5 SW Java Black
Hi all,
Does anyone have a step by step of putting the adapters on and then the seat rails on - I can't screw everything from on top.
I've got the adapters onto the rails - but bolting the rails to the seat itself is a problem - the handle to move the rails is in the way of the hole for the front bolts.
Anyone any ideas??
Thnkya! http://mylandy90.blogspot.ie/
Post #460358 4th Oct 2015 4:57pm
