Home > Maintenance & Modifications > installation of recaro's |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
Hi guys, little bit stumped, got a set of recaro sportster's,
also purchased 'tune my defender' seat rails... i have no idea what im doing, also the seat rails powder coat puts land rover's paint department to shame, as seen here are the rails, the problem is acessing the bolts to righten them down... any one got photos or tips? i.e. removing the base and doing something...? ive removed the bases to see but still no help. |
16th Jul 2013 3:43pm |
so completly take the whole set up from ontop of the seat boxes, assemble then bolt back together like that?
here's a pic, seat base is still in place but even with it removed, the frame still gets in the way, might completely removed the frame from the seat box but then i dont think it will go back together (have to check how its bolted inside the seat box... |
16th Jul 2013 3:54pm |
Click image to enlarge hmm |
16th Jul 2013 4:13pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20322 |
Remove the seat and seat frame and then re-assemble. The bolts are captive nuts in the seatboxes so there is nothing underneath all done from the top.
You might find you have to take the frame out fix to the seat then put the lot in together and bolt down. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
16th Jul 2013 4:15pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Sorry if this is stating the obvious but normally you bolt the runners to the seat, and then more seat forward / backwards to bolt to the seat box - should be simple. Obviously I'm missing something 2020 P300 HSE
16th Jul 2013 4:17pm |
getting at the bolts is quite interesting, the adapters imo are a terrible design but they were the only ones available, nothing lines up even to a half acceptable measure so its a lot of faffing, you have to install 1 bolt then 3 with the runner at a 30 degree angle only tightening a small amount, then the rear, 2, then back to the front boa bla bla... its a pig.
16th Jul 2013 6:35pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
Something to take up with the supplier of the adapter then. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Jul 2013 7:30pm |
The email is sent, with photos, the finish for one is not acceptable, be interesting to hear there side
16th Jul 2013 7:34pm |
16th Jul 2013 8:07pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
any news?
29th Sep 2013 9:34am |
sent me another set out... not that impressed with the quality but i couldn't wait for the alive ones to be made so these were my only option.
29th Sep 2013 2:45pm |
so the recaro ones aren't available?
29th Sep 2013 4:50pm |
ask gary @ alive, when we spoke they weren't seem to remember him emailing me to say he had some if it wasn't too late... which it was
1st Oct 2013 6:10pm |
hamtheman Member Since: 19 Mar 2013 Location: Louth Posts: 35 |
Hi all,
Does anyone have a step by step of putting the adapters on and then the seat rails on - I can't screw everything from on top. I've got the adapters onto the rails - but bolting the rails to the seat itself is a problem - the handle to move the rails is in the way of the hole for the front bolts. Anyone any ideas?? Thnkya! http://mylandy90.blogspot.ie/ |
4th Oct 2015 3:57pm |
