Home > Wheels & Tyres > Puma OE Alloy wheel nut replacements
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
Hello
After buying a 27mm socket, it seems either I've bought the wrong size or the wheel nuts have swollen. If the nuts have swollen, should I just buy the same stainless capped nuts, and replace them every 5 years or so. Or should I replace them with something different? Is where can I buy these?
Richard
Post #265950 12th Sep 2013 10:23am
There's no reason why alloy wheel nuts should wear out and need replacing every five years Confused Either something very unusual has occurred or you've bought the wrong socket. Darren
Post #265972 12th Sep 2013 12:48pm
rleslie
cheers Darren
So can someone confirm its a 28mm socket before I go and buy one!
cheers
Post #265975 12th Sep 2013 12:52pm
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
It was 27mm for the Boost alloys on my 2009 model.
Post #265979 12th Sep 2013 12:57pm
27mm however swollen nuts are comon im afraid Thumbs Up
Post #265988 12th Sep 2013 1:35pm
Really? Never heard of it before Confused Darren
Post #265992 12th Sep 2013 1:43pm
I led to believe it’s our old adversary bi metallic corrosion between the nut and cover
Post #265997 12th Sep 2013 2:08pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
It would seem not that uncommon. Land Rover vehicles appear frequently, but also others. Big Cry
https://www.google.co.uk/search?q=swollen+...ent=safari LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #266003 12th Sep 2013 2:36pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
For some reason I involuntarily crossed my legs when I read this post. Shocked BM52
Post #266017 12th Sep 2013 2:58pm
MartinK
Yep, the nuts do swell.
I've got a bag of them in the garage to replace them when they swell too much for the 27mm socket... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #266032 12th Sep 2013 3:54pm
rleslie
Cheers Guys.
So I take it I just buy the same Censored ones again? No after market ones that don't rust and don't swell....
Thanks
Post #266218 13th Sep 2013 6:32am
rosscomax
Scotland 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hi,
my ones are the same, bought a new set from ebay but they are crap, stainless covers fall off after fitting!!
Have you found anyone who supplies solid ones??
Post #282502 15th Nov 2013 6:53pm
munch90
Best thing I found is to soak the nuts (before they are corroded ) in thinned waxoyl or any good any rust fluid overnight then quick wide off then let then dry ...seems to help stop them corroding inside under the cap
Post #282566 15th Nov 2013 10:48pm
HardCharger
Apologies for reviving an old thread but I have need to know regarding these things.
When I got my truck from the previous owner, I negotiated the acquisition of his boost alloys and corresponding wheel nuts as well. He reluctantly gave them over on the condition that I hand over the original steel wheels, the wheel nuts for the steel wheels and for the spare, and the 27mm tire wrench as it was useless to me. Upon fitting, the alloy wheel nuts he gave me were all 28mm rather than 27mm but the guy who put them on apparently used a 12 sided spanner rather a proper 6 sided socket hence deforming some of the wheel nut covers. Upon looking for replacements, I found out that even alloy wheel nuts with stainless covers for the Defender are 27mm and not 28mm! Does this mean that all the wheel nuts that I was given were all swollen?!
In any case, my options now are to either acquire wheel nuts with stainless covers or the solid steel wheel nuts for alloys. I was told that while the wheel nuts with stainless covers look nice, the solid steel ones last forever.
What do all y'all think?
Thanks.
Post #436813 10th Jul 2015 5:59am
OEM Nut is 27mm the 28mm is a get around
Just buy new 27mm nuts I'm sure Mal (K9) will provide the relevant link to a great aftermarket supplier
Post #436814 10th Jul 2015 6:04am
