![]() | Home > Land Rover Customer Relations > 2.2 flat spots |
CRC@LandRover Verified Account ![]() Member Since: 25 Mar 2013 Location: Coventry Posts: 383 ![]() ![]() |
Hello,
I am not aware of any flat spot issue. I suggest if you are having any issues then you book your vehicle in with your local dealership then we can try and solve the problem for you. Many Thanks Mike |
Mike - what did Q225 TSB actually refer to?
'PM' wsir as per last post in this thread..... ![]() http://www.defender2.net/forum/topic21130.html?highlight=q225 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 9th Sep 2013 12:25pm. Edited 1 time in total |
Hello,
As above it related to the following concerns: 1) AMBER lamp for DPF on EU5 calibrations illuminating too frequently due to overestimation of soot loading which can lead to a high fuel content in the engine oil due to too frequent regeneration. 2) Driveline oscillation (vibration) at low speed. 3) Hesitation on acceleration after previously backing off on the throttle pedal. Many Thanks Mike |
Mike - "Hesitation on acceleration after previously backing off on the throttle pedal " would be called a flat spot issue in most people's mind - a response of "I am not aware of any flat spot issue" perhaps unintentionally sounds very much like a generalised corporate rebuff
Hello,
Q225 came out to resolve any issues relating to this. So we are not aware of any outstanding issues. So if you do have an issue then please take your vehicle into a dealership. Many Thanks Mike |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
I've got this issue on a May 2013 build.
Always happens when I back off and then re-accelerate in the same gear. It's almost as though the engine stops momentarily. My Disco 'best bits' Defender 110 XS CSW 2013 |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 ![]() ![]() |
Supacat and disco,
Exactly what I have........and why Caffyns applied the update.......didn't stop the issue though and has become more frequent. Vehicles heading to dealers for 1st service soon. Cheers. |
Supacat and disco,
a couple at least to look into... |
Once vehicles are taken into Land Rover dealerships we will be more then happy to investigate any issues for you.
Many Thanks Mike |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Mike
I bought an ex Landrover Experience 110 from Pentland Edinurgh a couple of weeks ago, over the past few days it has started suffering badly from flat spots and hiccups on acceleration, if I PM my VIN No could you check if the car has any updates outstanding as I don't have a lot of faith in the dealer. Thanks John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Hi John,
Yes I will be able to see if there are any service actions or recalls outstanding. Many Thanks Mike |
Thanks Mike
PM sent 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
