Home > Land Rover Customer Relations > 2.2 flat spots
Page 1 of 5 12345>
bob neville
2.2 flat spots
Hi Mike
There seems to a trend developing here - my 2.2 is only three months old and has the same problem that others describe.
http://defender2.net/forum/topic21205.html
http://defender2.net/forum/topic21191.html
Would LR like to comment, especially what is the Q225 TSB and which vehicles does it apply to ?
2013 Defender 90 CSW - sold
Post #244468 17th Jun 2013 8:42pm
Defender-Stu
8k on my clock and had a couple if moments of this too Evil or Very Mad
But only since its got a little warmer/humid ?
Post #244485 17th Jun 2013 9:14pm
CRC@LandRover
Verified Account
Verified Account
Hello to you both,
Q225 relates to certain 2012 Model Year Defenders.
If you or anyone else is experiencing this sort of thing then I suggest you book your vehicle in with your local Land Rover dealership.
If you would like me to see if your vehicle is affected by Q225 then just PM me your VIN number and I can look for you.
As far as I am aware the temperature shouldn't affect this.
Many Thanks
Mike
Post #244578 18th Jun 2013 10:09am
K9F
Not really related to this thread and a little off track so apologies in advance.....
Stu with my 2.4 I can relate to a change in engine performance with regards to ambient temperature and it was frustrating to say the least. Above 16 degrees my Defender used to suffer from overboost conditions (similar to fuel shut off momentarily switching on and off) at higher speeds but when the temperature was below 16 degrees it ran sweet as a nut. Sorted now though. But that was down to ECU programming so it would be worth checking on the Q225 recall.
It'll be free and no it won't drive like a Ferrari or Porsche afterwards.....but may sort your issue out hopefully! Laughing
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244582 18th Jun 2013 10:28am
SGH
Seems my 130 is infected too Laughing
Post #244588 18th Jun 2013 10:53am
Defender-Stu
Cheers Mal i will get on to LR now and see as need to book it back in for other little items Rolling Eyes Thumbs Up
Post #244590 18th Jun 2013 10:58am
K9F
Laughing Think I know where you're headed but it's not speed limiter related! Laughing
Would your 130 ever get there? Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244591 18th Jun 2013 11:05am
SGH
I'll have to blow the dust of it first Laughing
Post #244593 18th Jun 2013 11:10am
Defender-Stu
Just driven the 90 for the past hour and no problems and in traffic also, just gave it some so to speak Thumbs Up , spoke to LR and Mine has the current SW already Thumbs Up
Post #244610 18th Jun 2013 12:11pm
K9F wrote:
... Above 16 degrees my Defender used to suffer from overboost conditions (similar to fuel shut off momentarily switching on and off) at higher speeds but when the temperature was below 16 degrees it ran sweet as a nut....
Did you get an overboost fault logged in the ECU when this happened?
When my 2.4 was doing something very similar it never logged any faults, persisted or otherwise!
Post #244635 18th Jun 2013 1:09pm
Defender-Stu
Hi Blackwolf, K9F will reply but i thought i would add that i had not fault codes last week when i had my service and it had done this before that Thumbs Up
Post #244638 18th Jun 2013 1:58pm
K9F
Blackwolf no faults logged. Another remap installed and fault no longer exists. Problems only started after Q068 upgrade and it's incompatability with an Autologic map. Ancient history thankfully but it was temperature and ECU related.
Post #244797 18th Jun 2013 11:40pm
Interesting. May I ask how you know it was overboosting?
Mine started some while after installing the original BAS map, but remained unaltered if the original (factory) map was reinstalled, which made me think that it was a sensor malfunction or something of that nature (poss TPS malfunction, since this caused similar symptoms on my Disco 2 some years ago). However absolutely no faults of any kind either persisterd or otherwise were being logged, which I would have expected with a faulty sensor! Makes it hard to diagnose!
The sympstoms disappeared completely after installing the most recent BAS map, which has had other unexpected benefits (such as a whopping 10% improvement in MPG, as well as making the engine much quieter) as well as making the vehicle much nicer to drive.
All in all I am puzzled by the phenomenon since the fact that it was unaltered by changing between the first two maps suggested that it wasn't ECU-related whilst its diappearance with the third map suggests that it is. Strange!
Post #244813 19th Jun 2013 7:58am
K9F
Off Topic ish in reply to Blackwolf....
I used to have an Autologic map that was rendered 'incompatable' after the Q068 upgrade a couple of years ago. As you know the Autologic map was a generic map for standard vehicles with no upgrades or tweaks available. After Autologic sorted out the issues with Q068 I was invited to Oxfordshire to have the new version installed. On the day and on test runs the vehicle was overboosting quite horrendously. I am not aware of the intracacies of what they actually did but as was explained to me they 'shaved off' the top end of the map to prevent the overboosting symptoms. I thought they had it sorted but the map never really ran the same afterwards and when the ambient temperature got above 16 degrees (also at about 90mph on a private road whilst wearing a fire retardant suit, crash helmet and any other safety gear people would wish me to wear) the overboost symptoms would return (almost the same symptoms as hitting the old speed limiter). With various other ensuing modifications such as CAT and backbox removal etc. the symptoms didn't get any worse but obviously I wasn't going to be making things any better. In colder temperatures the Defender would just keep pulling and ran quite well.
It is now at long last sorted thankfully the same way as yours by the sound of it, with a subsequent remap swapout! At the time of my incompatability issues I received a lot of help and advice from Pete (more than Autologic initially) despite the fact he was under no obligation to offer it, for which I have been always grateful. Hindsight is a wonderful thing and I have at last ventured down the path I should perhaps have travelled three - four years ago?
More details here: Thumbs Up
http://www.defender2.net/forum/topic3243.html?highlight=lost If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244816 19th Jun 2013 8:41am
Aha, now I understand. Thumbs Up
Thanks. Very Happy
Post #244868 19th Jun 2013 3:20pm
Page 1 of 5 12345>
