Home > Maintenance & Modifications > Improving Turning Circle |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Which is the best way to improve the poor turning circle on the 110 CSW?
I'm led to believe the options are wheel spacers (seem expensive at around £200) or change the alloys for ZU or similar with bigger offset? Any experiences folks? Andy |
6th Jul 2008 9:49pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Or simply wind the stops in a bit
7th Jul 2008 9:55am |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
So with standard wheels and tyres, how many turns would be considered safe? And roughly what radial turning-circle distance reduction equates to a full turn? 2007 Defender 110
1970 Alfa Romeo 1750GTV |
7th Jul 2008 11:03am |
Daft question then, why set the stops that far out in the first place? I would have thought they would be set up to give maximum turning without rubbing Andy |
7th Jul 2008 12:04pm |
That is the million dollar question and I don't know the answer. It would have been set at the factory to allow the wheels to turn but not go too far as I presume damage to the CV joints would occur at full lock + |
7th Jul 2008 4:46pm |
Chaser Member Since: 03 Aug 2008 Location: brisbane Posts: 9 |
HI guys
I am not sure where you would wind out to fix this problem? anyone with photos? thanks if it moves shoot it, if it dosn't push it. |
28th Aug 2008 9:21am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The stops are there partly to restrict movement of the CV joint and prolong the life of the joint barings.
And at the same time prevent tyre rub. Regards Pete |
28th Aug 2008 4:09pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
So whats the answer on this.
I took the 90 round the Mcdonalds drive through and had to shunt on full lock to get to the window - surely that isnt correct? Mike |
28th Aug 2008 4:43pm |
Here is how
Regards Pete www.bellautoservices.co.uk/Defender-Steering-lock-adjustment.pdf If someone can upload direct to the forum then please do so other wise ill leave on my server. |
28th Aug 2008 5:18pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
29th Aug 2008 6:56am |
krispe Member Since: 04 Nov 2011 Location: Hornsby NSW Posts: 19 |
Anyone know where this file is located now, no longer on Pete's site. Kris |
14th Jan 2012 7:07am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
goto KFC. Pom |
14th Jan 2012 8:34am |
far superiour |
14th Jan 2012 10:12am |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
Anyone? Would like to tighten my turning circle, stops currently appears to be set about 3/4 inch out. don't want to get it wrong Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
23rd Jan 2012 6:06pm |
