Home > Maintenance & Modifications > Improving Turning Circle
CFB
Which is the best way to improve the poor turning circle on the 110 CSW?
I'm led to believe the options are wheel spacers (seem expensive at around £200) or change the alloys for ZU or similar with bigger offset?
Any experiences folks? Andy
Post #2638 6th Jul 2008 9:49pm
AndrewS
Or simply wind the stops in a bit
Post #2646 7th Jul 2008 9:55am
TJ101
Yep, worked for me,, certainly better !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2648 7th Jul 2008 10:38am
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
So with standard wheels and tyres, how many turns would be considered safe? And roughly what radial turning-circle distance reduction equates to a full turn? 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2649 7th Jul 2008 11:03am
CFB
Daft question then, why set the stops that far out in the first place? I would have thought they would be set up to give maximum turning without rubbing Confused Andy
Post #2650 7th Jul 2008 12:04pm
AndrewS
That is the million dollar question and I don't know the answer.
It would have been set at the factory to allow the wheels to turn but not go too far as I presume damage to the CV joints would occur at full lock +
Post #2655 7th Jul 2008 4:46pm
Chaser
Australia 2007 Defender 110 Puma 2.4 SW Alpine White
HI guys
I am not sure where you would wind out to fix this problem?
anyone with photos?
thanks if it moves shoot it, if it dosn't push it.
Post #3351 28th Aug 2008 9:21am
bell-auto-services
The stops are there partly to restrict movement of the CV joint and prolong the life of the joint barings.
And at the same time prevent tyre rub.
Regards Pete
Post #3388 28th Aug 2008 4:09pm
mse
So whats the answer on this.
I took the 90 round the Mcdonalds drive through and had to shunt on full lock to get to the window - surely that isnt correct? Mike
Post #3397 28th Aug 2008 4:43pm
bell-auto-services
Here is how
Regards Pete
www.bellautoservices.co.uk/Defender-Steering-lock-adjustment.pdf
If someone can upload direct to the forum then please do so other wise ill leave on my server.
Post #3400 28th Aug 2008 5:18pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Thanks Pete, just the information! 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3424 29th Aug 2008 6:56am
krispe
Australia 2012 Defender 110 Puma 2.2 SW Indus Silver
bell-auto-services wrote:
Here is how
Regards Pete
Anyone know where this file is located now, no longer on Pete's site.
Kris
Post #115256 14th Jan 2012 7:07am
pom
goto KFC.
Pom
Post #115272 14th Jan 2012 8:34am
goto KFC.
Pom
far superiour Bow down
Post #115296 14th Jan 2012 10:12am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Here is how
Regards Pete
Kris
Anyone? Would like to tighten my turning circle, stops currently appears to be set about 3/4 inch out. don't want to get it wrong Very Happy
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #117840 23rd Jan 2012 6:06pm
