Home > In Car Electronics > Is there a way to support the stereo??
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've recently swapped the radio in my Td5 90 to a newer L/R unit but it must be slightly heavier, it is slipping down and gradually sits at an angle, is there a way of keeping it from slipping, it's the back that will need supporting in some way, maybe a bit of wire hooked around it at the back?
Has anyone had a similar problem and cured it? It's a bit of a pain to take the dash out again, is there any easy way of getting behind again?
Post #263236 2nd Sep 2013 8:51pm
Slide the HU out.. You should find a female threaded support hole at the rear (depends on make and model) You should be able to work something out with that. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #263245 2nd Sep 2013 9:11pm
Lambley
Ok, thank you, i'll have a look tomorrow. I knew it'd be something simple!
Post #263248 2nd Sep 2013 9:16pm
landy andy
Normaly new head units are supplied with small threaded bar, and a rubber cover that goes over that. It screws into rear of hu and into hole at rear of dash for support.
Andy
Post #263260 2nd Sep 2013 9:40pm
Some have them and some don't. I can't remember mine having the above from purchase although possibly I lost it. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #263265 2nd Sep 2013 9:55pm
landy andy
The alpine I fitted last week had one in with it Thumbs Up
Andy
Post #263271 2nd Sep 2013 10:12pm
JWL
I have a block of wood under mine at the back Whistle Bit agricultural, but it works Thumbs Up
Post #263288 2nd Sep 2013 11:04pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I found an old radio with one fitted (luckily) after having the same problem - actually a bit worse as the whole thing vibrated out whilst in Morocco Smile
A bit of tape on the front worked for a while until I got fed up with the mess and found the pluh thing. All fine now.
Tony
Post #263382 3rd Sep 2013 12:22pm
