![]() | Home > In Car Electronics > Is there a way to support the stereo?? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
Slide the HU out.. You should find a female threaded support hole at the rear (depends on make and model) You should be able to work something out with that.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Ok, thank you, i'll have a look tomorrow. I knew it'd be something simple!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
Normaly new head units are supplied with small threaded bar, and a rubber cover that goes over that. It screws into rear of hu and into hole at rear of dash for support.
Andy |
Some have them and some don't. I can't remember mine having the above from purchase although possibly I lost it. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
The alpine I fitted last week had one in with it
![]() Andy |
I have a block of wood under mine at the back
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
I found an old radio with one fitted (luckily) after having the same problem - actually a bit worse as the whole thing vibrated out whilst in Morocco
![]() A bit of tape on the front worked for a while until I got fed up with the mess and found the pluh thing. All fine now. Tony |
