Home > Maintenance & Modifications > How many Dinitrol cans?
Page 3 of 3 <123
I just used a 3M mask (paint maksk) safety specs too although a pain to see with they really are needed. Other than that just a pair of overalls. Any of the rest on your hair or what ever is curable by having a good bath lol
Just don't go lying around the living room afterwards or you'll certainly be in for the chop! Whistle
I masked off the whole exhaust or removal is another option. Masked the props and also the handbrake drum. masked the lower seals each side and steps. Fuel pipes (both return and filler) and fuel filter lower assembly. Removed the fuel filter guard for ease of access and done that separate to the LR on it's own. In my case you may not have one but also masked my steering guard and lower painted edge at the front.
And finally to keep any over spray off the brake discs (I painted the stone shields) I carefully put in paper all the way around between the disc and the shield to keep it from getting on the discs. Yes, you could take the wheel off and put a bag over it but the effort and safety side put me off of that.
Last thing was a bit of tape along any gaps in the rear body to rear crossmember again to prevent possible overspray. Which absolutely would have happened.
I just have the internal wax to do but that's relatively easy and won't require any masking.
Ideally you want two brand new rolls of tape for a 90 and maybe more for a 110 you'd be surprised how much you use.
Oh and I masked off the mud flaps too. KEEP CALM AND Drill ON
Post #261391 26th Aug 2013 3:10pm
Sockpuppet
So basically you're saying there is lots of masking Laughing
Right, better start reading the Times for the next few weeks, seems like I'd need the newspaper.
Post #261409 26th Aug 2013 4:40pm
ericvv
Steve, masking off the mud flaps is not good enough, that's just a short cut, you have to take them off so that the outriggers are properly covered everywhere with Dinitrol. Like below... Thumbs Up
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #261411 26th Aug 2013 4:53pm
Bow down Bow down KEEP CALM AND Drill ON
Post #261464 26th Aug 2013 8:02pm
Forgot I didn't add any photo's of mine done... Rolling Eyes
So went from this:
To this:
Only got the internal wax to put in now which I will do soon. KEEP CALM AND Drill ON
Post #261677 27th Aug 2013 5:58pm
Green Machine
Looks good Steve, hopefully that will keep the rust at bay for a while longer! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #261678 27th Aug 2013 6:00pm
Sockpuppet
Really, really nice job there.
Post #261687 27th Aug 2013 6:22pm
GUM97
Proper job there Steve Thumbs Up An engine to TDi for!
Post #261689 27th Aug 2013 6:25pm
Thanks chaps. Mr. Green Not a job I'd like to undertake too often. Laughing Two days pretty much I spent under there scrabbling around. Shocked KEEP CALM AND Drill ON
Post #261711 27th Aug 2013 7:34pm
Page 3 of 3 <123
