Home > Maintenance & Modifications > How many Dinitrol cans?
Page 2 of 3 <123>
Sockpuppet
Is there a great difference between the 1litre cans and the aerosols. I'm weighing up if I can justify a compressor for the garage if there is little difference I wouldn't bother.
Post #259665 18th Aug 2013 6:46pm
I think you get a little more for your money on the 1ltr cans for a compressor but they cost the same pretty much and add a compressor to that too your talking £200 + and that's even providing you do it yourself.
Depends if you need one for other reasons though too. KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #259666 18th Aug 2013 6:51pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Is dinitrol better than waxoyl? And if so what type is best as there appears to be many different types?
Post #259683 18th Aug 2013 7:25pm
Sockpuppet
Basically.....
Dinitrol ML is a cavity wax. Inside the chassis, doors, bulkhead etc.
then the underbody sealer. These are the same just one is black. One is brown.
DINITROL 4941 - black, tough, elastic and waxy film
DINITROL 4942 - brown, tough, elastic and waxy film
Post #259719 18th Aug 2013 8:55pm
There is also brown internal wax or clear too. I've gone for brown on that so you can tell it's done plus it won't be seen anyway. The underseal will be black though. KEEP CALM AND Drill ON
Post #259723 18th Aug 2013 8:59pm
Well I've just bought all what I need. As I'm doing stone chip too I think it's cost around the £140 region. Shocked Still if a jobs worth doing it's worth doing properly! I don't relish the idea of scrabbling about under there too often!
Very Happy KEEP CALM AND Drill ON
Post #259886 19th Aug 2013 1:40pm
I've now got as of today all of this:
8x Stone chip, 8x under body wax and 6x internal wax.
Maybe a little too much (perhaps) but if it is won't do no harm with some spare. Very Happy KEEP CALM AND Drill ON
Post #260103 20th Aug 2013 4:41pm
Sphere
Whee you using the stone chip just under the arches?
Post #260140 20th Aug 2013 7:16pm
SGH
Steve
Did you get this from Rejel as they should supply DINITROL 445 500ml AEROSOL BLACK Stonechip
Simon
Post #260150 20th Aug 2013 7:49pm
Sphere - Yes, but probably only the rear the fronts plastic is no point doing IMO but the rears certainly. Thumbs Up
SGH (Simon) - Yep, from Rejel. I got some of the items in separate orders so it isn't a "kit" but more a built up kit. I bought the Autotek stonechip first before I knew Rejel did it and also I've had Autotek acid etch primer before with great results so I thought I'd stick with that. Ultimately it will be covered up anyway.
The Dititrol stonechip is also a bit more expensive of which as it'll be waxed over anyway I'm not fussed.
All personal choices really. I trust both brand names.
Smile KEEP CALM AND Drill ON
Post #260173 20th Aug 2013 8:24pm
Finished cleaning it a while ago. Done the Kurust stage today what I intend to do. Tomorrow stonechip hopefully.
Got a 3m paint mask too (may as well it's a confined space)
Post #260900 23rd Aug 2013 8:29pm
Done the stonechip stage today after masking off. Pity the weather wasn't a bit brighter though. Had to get a work light to see properly. Rolling Eyes
Post #261044 24th Aug 2013 7:50pm
GUM97
Very nice a Steve, but for the wax you need an Indiana Jones hat Wink An engine to TDi for!
Post #261049 24th Aug 2013 7:58pm
Dinitrol waxing done & what a messy job it is to do too. Shocked Went on really nice though and helped having a nice day too.. KEEP CALM AND Drill ON
Post #261364 26th Aug 2013 1:12pm
Sockpuppet
Looking good steve, I'm currently trying to find paper suits in size chunky in prep for doing mine.
Did you mask off the bolt heads/drain plugs, or don't you think it'll stop you undoing them in the future?
Post #261373 26th Aug 2013 1:52pm
Page 2 of 3 <123>
