Home > Maintenance & Modifications > How many Dinitrol cans? |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 |
just done my 110, bought the large car kit, 10 cans underbody sealer and 7 cans cavity wax, i put plenty on and filled the chassis till it was dripping out everywhere, i had 1/2 can of the sealer left over and 1 can of cavity wax, i sprayed everything except obviously prop, exhaust, engine, brakes. as per zagatos instructions i did the sealer first then the cavity wax as it drips everywhere, kept a can of the sealer back to spray over where the cavity wax runs down the chassis, as its brown. hopefully that will give you some idea until someone with a 90 comes along LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
17th Aug 2013 5:46pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20549 |
Just a little less then I'd imagine. What sort of finish does the underseal leave a black waxy finish? KEEP CALM AND Drill ON
17th Aug 2013 9:13pm |
yes, leaves a matt black hardish/rubbery finish but apparrently stays soft underneath, it looks like its just been painted matt black, the spray cans have a nice spray nozzle on them and buy the gun adapter for the top of the can. it saves that spray can finger syndrome and its only a few quid,
looks very nice and how it should look from the factory, i had wanted to do mine for a year and was concerned how it would look but now i`ve done it i would highly recommend it, and dont worry about getting runs in it as they soon dissappear, i got a few and came back to them a bit later and they had blended in i parked mine on a big plastic sheet on my grass as the cavity wax does make a mess but the underbody sealer hardly makes any mess at all, i did wear overalls but no gloves/mask/hard hat or condom. !!!!!!!!!! any overspray wipes off with WD40. i`ll try and get some pictures tomorrow. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
17th Aug 2013 9:45pm |
Thank-you for the reply some really useful info there.
Pictures would be great if you get the chance. I was also going to stone chip it too before all this, after all I have cleaned the lot too perfection nearly so I may as well finish what I started properly. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
17th Aug 2013 10:08pm |
good idea, i had`nt thought about that until i read another forum member said he had done his axles and wheel arches, but as id decided to do mine the next day(having had the kit sitting in the garage for a month) i did`nt have time to buy any, but ill see how mine fairs over the coming months LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
17th Aug 2013 10:17pm |
It shouldn't make too much difference but it's an extra layer of protection and something good forthe wax to cling onto. The couple of light rusty areas I'm going to clean up and Kurust first. So it will have been: Fully cleaned, dried out, rust areas cleaned and Kurust applied, stone chipped, chassis waxed, internals waxed.
And plenty of masking too I expect. If this weather sorts it's self out. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Aug 2013 9:00am |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Sorry not the best photos LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
18th Aug 2013 10:08am |
That's excellent. Thank-you for doing that. I've just wrestled my clamp on diff guards off to give it a clean up too. Probably get QT's at some point but either way they had to come off.m I'll also have the springs to do as well. KEEP CALM AND Drill ON
18th Aug 2013 10:57am |
not sure why their sideways, i loaded straight from my phone which i was holding upright ???????????? the finish looks a lot better in the flesh,
i also got away with hardly any masking up as the can spray is fairly accurate, LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
18th Aug 2013 1:32pm |
That's good.
I took off my diff guards today to do a proper clean up and they'll stay of for now. All bar the wheel arches (mainly the rears) I have cleaned and de-greased the lot. Click image to enlarge KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Aug 2013 3:51pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
^^Looks good mate! Not bad at all for nearly 6 years old! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
18th Aug 2013 4:19pm |
Nope, not been treated either. Mind you I do look after her well. KEEP CALM AND Drill ON
18th Aug 2013 4:21pm |
It's called Zag Syndrome An engine to TDi for!
18th Aug 2013 4:22pm |
Well at least it's not painted White. KEEP CALM AND Drill ON
18th Aug 2013 4:36pm |
