Home > In Car Electronics > Microphone placement - handsfree
HTB
United Kingdom 2012 Defender 90 Puma 2.2 HT Buckingham Blue
Is there anywhere that works particulalry well for the placement of a Handsfree microphone in a '12 Defender. Now I'm looking for photos of where they are placed as standard I cant find any. Any guidance would be greatly appreciated.
Thanks,
h
Post #257822 10th Aug 2013 9:36pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I've put mine top right hand corner of windscreen
Run cable up behind A pillar trim Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #257832 10th Aug 2013 9:57pm
As above for me too. You could have it central in the vehicle so it's passenger usable too but I found that having it on display on the dash I couldn't stand the look of so opted for the same method as above. KEEP CALM AND Drill ON
Post #257833 10th Aug 2013 10:03pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Have done the same as above and works well. Darren
Post #257834 10th Aug 2013 10:10pm
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
Yep I've done the same as above posters, just make sure it doesn't vibrate and I found its fine.
Post #257840 11th Aug 2013 1:11am
Romadog
I used to stick my microphone on the mirror mount on my Td5 to keep it as far from wind noise through door seal. People told me it was very clear.
Post #257850 11th Aug 2013 7:16am
K9F
I bought a Scangauge mirror blendmount and my microphone sits on top of my Scangauge. Central to the vehicle is good I reckon!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #257854 11th Aug 2013 8:11am
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Factory fit for MY13 is on the housing directly behind the steering wheel My Disco 'best bits'
Defender 110 XS CSW 2013
Post #257855 11th Aug 2013 8:21am
I fitted mine there, worked ok and the wires can be fed thru the back of the dash Thumbs Up
Post #257857 11th Aug 2013 8:27am
Green Machine
Got mine centred on top of the instrument binnacle as well in my Td5 and seems to work well. Was going to put it up the a-pillar, but then decided that on top of the instruments was closest to my mouth and in direct 'sound line' - seems to work very well (parrot system integrated into Kenwood HU). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #257871 11th Aug 2013 9:35am
Post #257934 11th Aug 2013 1:49pm
g13non
Ireland
This is where my mic sits (MY12).
Post #258001 11th Aug 2013 5:34pm
jimbob7
Mines on the interior light,a central position thats out of the way,don't know if an open window affects the sound quality.
Post #258011 11th Aug 2013 6:35pm
HTB
Thanks all - I'll go with the factory fit location.
As a matter of interest is there a trick for getting the 'recirc air' slider across to the recirculated air location on the slider - mine won't budge to the photo taken by g13non?
Post #258214 12th Aug 2013 4:29pm
Could be jumping the gun here but sounds to me like the cable is either broken or bent! Shocked I had the same last year and checked it out myself and this was what I had. KEEP CALM AND Drill ON
Post #258238 12th Aug 2013 6:50pm
