![]() | Home > In Car Electronics > Microphone placement - handsfree |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
I've put mine top right hand corner of windscreen
Run cable up behind A pillar trim ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20644 ![]() ![]() |
As above for me too. You could have it central in the vehicle so it's passenger usable too but I found that having it on display on the dash I couldn't stand the look of so opted for the same method as above. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Have done the same as above and works well. Darren
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 ![]() ![]() |
Yep I've done the same as above posters, just make sure it doesn't vibrate and I found its fine.
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I used to stick my microphone on the mirror mount on my Td5 to keep it as far from wind noise through door seal. People told me it was very clear.
I bought a Scangauge mirror blendmount and my microphone sits on top of my Scangauge. Central to the vehicle is good I reckon!
![]() Treat every day as if it is your last....one day you will be right!! |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
Factory fit for MY13 is on the housing directly behind the steering wheel My Disco 'best bits'
Defender 110 XS CSW 2013 |
I fitted mine there, worked ok and the wires can be fed thru the back of the dash ![]() |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Got mine centred on top of the instrument binnacle as well in my Td5 and seems to work well. Was going to put it up the a-pillar, but then decided that on top of the instruments was closest to my mouth and in direct 'sound line' - seems to work very well (parrot system integrated into Kenwood HU). 2005 Td5 | 90 Station Wagon | Tonga Green
[URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by Supacat on 11th Aug 2013 5:52pm. Edited 1 time in total |
g13non Member Since: 27 Oct 2011 Location: BIFFO Posts: 31 ![]() ![]() |
This is where my mic sits (MY12).
![]() Click image to enlarge ![]() Click image to enlarge |
Mines on the interior light,a central position thats out of the way,don't know if an open window affects the sound quality.
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 72 ![]() ![]() ![]() |
Thanks all - I'll go with the factory fit location.
As a matter of interest is there a trick for getting the 'recirc air' slider across to the recirculated air location on the slider - mine won't budge to the photo taken by g13non? |
Could be jumping the gun here but sounds to me like the cable is either broken or bent! ![]() β½οΈπ’οΈβοΈπ§°πͺ |
