Home > In Car Electronics > Fitting engine start (& stop) button(s)?
BigWheels
How easy would it be to have a dash mounted engine start button. Ignition would be turned on & stay on with the key , but the engine start would be by pushing the button. As for motorcycles & some cars. Not sure if the cars have kill switches, or if the ignition would still need turning off to do so. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #257135 7th Aug 2013 10:23pm
Cheshire110
Re: Fitting engine start (& stop) button(s)?
Why not just park your car with the door open & keys in the ignition in a car park in Liverpool! Same result! Cheers, David
Post #257136 7th Aug 2013 10:26pm
BigWheels
Not sure what you mean, Confused .. & if a curly wig & shell suit are needed as well Wink Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #257138 7th Aug 2013 10:31pm
Cheshire110
Don't see why it couldn't be done, but I'd guess you'd need to make security your number 1 priority then! It's bad enough anyway! Cheers, David
Post #257142 7th Aug 2013 10:52pm
WarPig
He still wants the ignition to be key operated. So no less secure than it is already.
Post #257152 7th Aug 2013 11:26pm
FranklyXS
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Aintree Green
not sure, but looks like this has one fitted..... if it has, then at least technically it could be done, if not financially Whistle
http://www.pistonheads.com/classifieds/use...4x4/926956
Post #257153 7th Aug 2013 11:41pm
bear100
i fitted one to my range rover classic a few years ago, it was real easy to fit, i would recommend fitting a good quality one the cheap ones don't last very long
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #257174 8th Aug 2013 7:11am
Martin
Site Admin
Buy a Series I Laughing
I do find it amusing that the "engine start" button is back in demand, technology had moved on to key start Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #257193 8th Aug 2013 9:02am
Technology now seems to have moved beyond key start, which is why a button is again needed. I recently had an Evoke on loan and the 'key' stayed in my pocket as there wasn't anywhere to insert it in the car.
Perhaps a button will eventually be replaced by thought control Laughing Darren
Post #257195 8th Aug 2013 9:18am
