Home > In Car Electronics > Fitting engine start (& stop) button(s)? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2767 |
Why not just park your car with the door open & keys in the ignition in a car park in Liverpool! Same result! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
7th Aug 2013 10:26pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Not sure what you mean, .. & if a curly wig & shell suit are needed as well Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
7th Aug 2013 10:31pm |
Don't see why it couldn't be done, but I'd guess you'd need to make security your number 1 priority then! It's bad enough anyway! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
7th Aug 2013 10:52pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
He still wants the ignition to be key operated. So no less secure than it is already. |
7th Aug 2013 11:26pm |
FranklyXS Member Since: 29 Jul 2013 Location: rather out than in Posts: 22 |
not sure, but looks like this has one fitted..... if it has, then at least technically it could be done, if not financially
http://www.pistonheads.com/classifieds/use...4x4/926956 |
7th Aug 2013 11:41pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1945 |
i fitted one to my range rover classic a few years ago, it was real easy to fit, i would recommend fitting a good quality one the cheap ones don't last very long
2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
8th Aug 2013 7:11am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Buy a Series I
I do find it amusing that the "engine start" button is back in demand, technology had moved on to key start 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Aug 2013 9:02am |
Technology now seems to have moved beyond key start, which is why a button is again needed. I recently had an Evoke on loan and the 'key' stayed in my pocket as there wasn't anywhere to insert it in the car.
Perhaps a button will eventually be replaced by thought control Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th Aug 2013 9:18am |
