Home > Technical > aframe joint |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Have a look at the Gwyn Lewis website as they sell one that can be adjusted-lubricated (can't remember which).
http://www.gwynlewis4x4.co.uk/ |
6th Aug 2013 12:43pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8041 |
its a wide angle one too for lifts/droop changes etc from Gwyn
do you have a press? if not it can be simpler to buy the whole thing in the holder, although obviously more expensive. if you have std suspension then a std one will work well. i use bearmach. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Aug 2013 2:44pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
I used a standard delphi one.
Adjustable ones are often not, after a few years of crud, salt and rust! as for installing/removing, it seems to be pot luck - mine came out with a deft whack with a lump hammer. |
6th Aug 2013 3:33pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 762 |
My Bearmach adjustable one has been in for over 10-years and I have only had to adjust it once.
I fitted it without having to resort to a press and then coated it liberally with Waxoyl, when I adjusted it earlier this year it was clean & corrosion free underneath the Waxoyl. When the time comes to replace it I will fit the same item. ONE LIFE, GET IT! |
6th Aug 2013 7:08pm |
stevetd5 Member Since: 15 Aug 2007 Location: Adelaide Posts: 37 |
Thanks all I will probably go adjustable, more likely to wear (corrugations) than rust here in Aust.
7th Aug 2013 9:31am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6606 |
Buy the whole thing in the holder (fulcrum).
Pretty certain Simon @ MPS will be able to supply it, and there's an OEM version too 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Aug 2013 11:32am |
