![]() | Home > Maintenance & Modifications > OIL CHANGE |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
The tiny paper filer is supposed to last 12k, I dropped it and couldn't find it as it rolled under a leaf. I've can't get the crush washer off, so I think that's why they specify a new bolt, it's stuck on.
Merlin |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
did mine recently and it was the easiest oil change I've ever done on any vehicle. Yes the filter is tiny - about the same size as the one on my 1L 3 cylinder Peugeot !
One little tip that worked for me. Normally you remove the oil filler cap to enable the oil to drain out of the sump fully but on the Puma don't do this until you have started draining. By leaving it on it slows the initial gush of dirty oil just enough to get your hand (holding the sump plug!) out of the way. You can then remove it once you have positioned the drain container properly. |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
mite be worth a look if you want to keep the price low,
http://www.defender2.net/forum/topic7086.html?highlight=filter and now they are site sponsers and are giving free delivery i think! mark |
The Manual says re the plastic oil filter housing:
That also seems awful tight for a plastic (I assume?) oil filter housing? My Volvo one is only 9Nm I think... Any thoughts> Has anyone used 35nm without distorting the filter housing???[/quote] Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Yes I've now done it 5 times. no problem with the torque, the housing is reinforced and takes it easily
I don't bother using a torque wrench. I just tighten it very slowly and gently with a normal socket until I can feel it stop. No leaks no damage
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
My oil-drain plug washer has almost gone. I can not find it in spare parts catalogue/service manual. Do you know the type/size of it? Janusz
www.yahodeville.com |
