Home > In Car Electronics > 'Hiss' from new amped speakers
Cheshire110
I've fitted some 6x9s in the rear of my 110, with an amp (both halfords)
The 6x9s only (other speakers are not amped) hiss all the time a little. It's most noticeable when the music is off but power on (amp stays on for 10-15 sec after IGN is switched off)
Anyone reccomend a common fix or likely culprit? Cheers, David
Post #255903 3rd Aug 2013 8:38am
How have you routed your cabling? And how loud is the "hiss" ? Thumbs Up No Guts, No Glory.
Post #255904 3rd Aug 2013 8:40am
Cheshire110
the cable routing isnt particularly tidy now you speak of it - a couple of joins and runs up B pillar, past alpine lights and down rear window trim to speakers. Could joins etc be a problem? Cheers, David
Post #255909 3rd Aug 2013 8:55am
K9F
'Joins' can indeed be a source of interference. They need to be well-made, preferrably soldered and subsequently insulated. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255920 3rd Aug 2013 9:29am
As Mal say's above. If there is any power cables and signal cables mixed together that isn't good either try and separate them as best you can. Thumbs Up No Guts, No Glory.
Post #255945 3rd Aug 2013 11:44am
barbel jim
New 'short' earth to the amp usually sorts, and is where I would start. Thumbs Up Thumbs Up
Post #255948 3rd Aug 2013 12:30pm
K9F
Short earth on the amp is a very good idea but will not help if your problem is on the speaker output side of it. Do check both areas mentioned. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255973 3rd Aug 2013 3:56pm
I think it's most likely to do with Amp to speaker rather than primary power but could be wrong. No Guts, No Glory.
Post #256042 3rd Aug 2013 7:55pm
Cheshire110
Thanks for the advice everyone! Will look into it Cheers, David
Post #256060 3rd Aug 2013 8:41pm
K9F
We use at work a Public Address sytem on the vessels with four TQA amplifiers supplying over 120 speakers with 6 auxilliary inputs plus a cascade system with descending 'priority' starting at the Captain's microphone . Trying to find the source of interference on that can be a proverbial nightmare. 9 times out of 10 it'll be a speaker dragging or degrading the system down.
If you still have your old speakers disconnect your fitted speakers and try connecting one of the previously removed directly to the back of the amp if convenient, this will give a good pointer perhaps where your problem lies. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #256102 3rd Aug 2013 10:29pm
