Home > Technical > hand brake warning light and a grinding sound... |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2646 |
hand brake warning light comes on when on bumpy terrain or steep downhill's, also hearing a slight grinding sound coming from underneath, anyone experienced this / got ideas ? on a puma 90..
couldn't say if both happen at same time but grinding noticeable after the warning light starts flickering |
1st Aug 2013 7:56pm |
partly my thinking, the car did sit for 5 months but i dont think the hand brake was left on...
1st Aug 2013 8:07pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Brake fluid low? - this puts the handbrake light on as well. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
1st Aug 2013 9:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
As stated above, the same warning light is used for low fluid. Steep downgrades especially when braking may activate it as the fluid runs to the front of the reservoir.
If your pads are worn to bare metal you'll get a grinding noise, and the level will be low due to the piston extension in the calipers. |
1st Aug 2013 9:17pm |
cheers
1st Aug 2013 9:21pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8099 |
low fluid
handbrake cable too tight sticking shoe combined with low fluid pads shot is the grinding noise only going down hill, only under braking or all the time? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Aug 2013 6:10am |
