Home > Maintenance & Modifications > what a tool.....
Page 2 of 2 <12
x-isle wrote:
Have to admit, when I was racing a few years back I was desperate to get hold of a certain socket size that I didn't have (can't remember what size) and the only option was Halfords.
The ratchets didn't last too long on the drives apart from the 1/2" is still going strong, but the sockets (and indeed the spanners) lasted, in fact, I still use them today and are still like new.
It seems to be fashionable to knock Halfords but they do sell some very good tools. I've got two of their socket sets that are both now well over twenty years old and in all that time I've only replaced one socket.
Their ratchet spanners are particularly useful too. Darren
Post #248280 2nd Jul 2013 9:42am
Halfords Professional range tools are as good as any, and have a lifetime warranty. Thumbs Up
Halfords other tools are just like any other high street supplier, ie cheap and nasty! Big Cry
The only problem with buying Halfords Pro is the risk that someone you know might see you in there and the consequent embarrassment! Embarassed
Post #248332 2nd Jul 2013 12:57pm
womble
i.ve got a small (i think 1/4 drive )teng socket set. Whistle you could put it in your pocket,and it was free with a subscription to 'classic and sportscar' it has been a great bit of kit.
Post #248578 2nd Jul 2013 10:48pm
Caterham
I've got a britpart tool from Simon at MPS.
.....even if the tool turns out to be rubbish (which I'm sure for my occasional use it'll be just fine) it was still money well spent cos the service was once again second to none.
thanks Simon.
Post #254402 29th Jul 2013 4:10pm
I just hope it fits, and the hex doesn't turn out to have five (or 7) sides! Sadly nothing would surprise me!
Post #254430 29th Jul 2013 6:18pm
rossy
Since I've had my Defender (2 Years) I've done all my work on it with a � 20 socket and spanner set from Aldi - including having to stand on and kick the ratchet as it struggled to remove the too tight square plugs on the diffs. The only socket I broke was one of the cheap (not that cheap either) Halfords ones Laughing
Post #254436 29th Jul 2013 6:28pm
Caterham
the tool looks fine.....
more likely the prop nuts / bolts will be round or triangular Neutral
Post #254452 29th Jul 2013 7:43pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Am currently waiting for my 110XS to arrive in September.
Up until now, I have always carried an extending wheel brace with socket to fit.
What size are the wheel nuts on a Defender, please? With luck I can use the same wheel brace with a decent socket instead of whatever short useless bit is provided. 1970 Series 2A 88"
Post #254460 29th Jul 2013 9:01pm
ickle
Don't forget that you are supposed to renew the prop shaft nuts (metal locking nuts) each time they are taken off - in an emergency certainly use some threadlock....
Post #254463 29th Jul 2013 9:19pm
Caterham
thanks ickle....
got some new ones just waiting to be fitted. (the old one are dirty are quite dirty now).
Post #254476 29th Jul 2013 9:45pm
27mm across the flats, if memory serves me. The supplied wrench is completely adequate unless you grotesquely overtighten your wheelnuts or are a weakling. You will of course need a socket for the torque wrench when doing them up.
Post #254534 30th Jul 2013 8:13am
lukev01
Good to hear. I haven't owned a Defender before, only my S2A but the daily drives usually came with a useless short bit of rubbish, completely inadequate when matched against the wheel nuts torqued on by some heavy handed chimpanzee at the tyre fitters. Having a larger wheel brace with these was usually a matter of common sense.
I also don't have a torque wrench. Is one of these essential when tightening wheel nuts? 1970 Series 2A 88"
Post #254535 30th Jul 2013 8:15am
Torque wrench is not essential but it a good idea. If you use the supplied wrench and tighten the nuts pretty firmly, they'll be about right. If you get the chance, see what correctly torqued nuts feel like with the normal wrench.
If a gorilla's tightened them you may find that a length of pipe slipped over the handle helps when loosening, but don't use it to tighten them.
Post #254634 30th Jul 2013 2:46pm
Page 2 of 2 <12
