![]() | Home > Maintenance & Modifications > what a tool..... |
It seems to be fashionable to knock Halfords but they do sell some very good tools. I've got two of their socket sets that are both now well over twenty years old and in all that time I've only replaced one socket. Their ratchet spanners are particularly useful too. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
womble Member Since: 27 Jan 2012 Location: south east Posts: 272 ![]() ![]() |
i.ve got a small (i think 1/4 drive )teng socket set.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
I've got a britpart tool from Simon at MPS.
.....even if the tool turns out to be rubbish (which I'm sure for my occasional use it'll be just fine) it was still money well spent cos the service was once again second to none. thanks Simon. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
I just hope it fits, and the hex doesn't turn out to have five (or 7) sides! Sadly nothing would surprise me!
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Since I've had my Defender (2 Years) I've done all my work on it with a € 20 socket and spanner set from Aldi - including having to stand on and kick the ratchet as it struggled to remove the too tight square plugs on the diffs. The only socket I broke was one of the cheap (not that cheap either) Halfords ones
the tool looks fine.....
more likely the prop nuts / bolts will be round or triangular ![]() |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Am currently waiting for my 110XS to arrive in September.
Up until now, I have always carried an extending wheel brace with socket to fit. What size are the wheel nuts on a Defender, please? With luck I can use the same wheel brace with a decent socket instead of whatever short useless bit is provided. 1970 Series 2A 88" |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
Don't forget that you are supposed to renew the prop shaft nuts (metal locking nuts) each time they are taken off - in an emergency certainly use some threadlock....
thanks ickle....
got some new ones just waiting to be fitted. (the old one are dirty are quite dirty now). |
27mm across the flats, if memory serves me. The supplied wrench is completely adequate unless you grotesquely overtighten your wheelnuts or are a weakling. You will of course need a socket for the torque wrench when doing them up. |
Good to hear. I haven't owned a Defender before, only my S2A but the daily drives usually came with a useless short bit of rubbish, completely inadequate when matched against the wheel nuts torqued on by some heavy handed chimpanzee at the tyre fitters. Having a larger wheel brace with these was usually a matter of common sense.
I also don't have a torque wrench. Is one of these essential when tightening wheel nuts? 1970 Series 2A 88" |
Torque wrench is not essential but it a good idea. If you use the supplied wrench and tighten the nuts pretty firmly, they'll be about right. If you get the chance, see what correctly torqued nuts feel like with the normal wrench.
If a gorilla's tightened them you may find that a length of pipe slipped over the handle helps when loosening, but don't use it to tighten them. |
