Home > Maintenance & Modifications > MSS or Mantec rear window guards? |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 |
mantec ones are drill and screww LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
28th Jul 2013 5:48pm |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
Hi Matt,
Cheers for the quick reply. Do you know if any drilling to the body itself is required or just through the trim? Apologies for the bone question! Craig Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
28th Jul 2013 5:55pm |
i only fitted the one rear window guard on the door as its a usw and drilled 10 holes, 4 up each side and 2 at the top around the glass frame. i would have thought the rear quarters and side window one would be the same but dont know for sure, if they were only in the trim they would have no strength LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
28th Jul 2013 6:04pm |
I thought exactly that regard the fitting to trim only, however, on Mantec's website the photo seems to show at least the top fixing points to attach to the trim. I don't know what's behind the trim as I haven't looked (yet) to see what the guard could attach to vehicle body wise.
Cheers again for the info, I do remember the rear window guard on my G4 USW having screws into the door body. Craig. Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
28th Jul 2013 6:27pm |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 |
I have the Mantech/G4 ones in mine they were already fitted when I bought it. The top of them screw to the trim as said above but the bottom the bolts go through some box section, which you slide in some threaded metal plates. I guess you have to drill the holes. Strong people are harder to kill and generally more useful!
28th Jul 2013 6:39pm |
Cheers for the info Thor, much appreciated. The ones in my old USW were Mantec prototypes and it being a USW I guess we're/are different than the SW variants. I guess it's just down to the make / style I buy now!
Cheers. Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
28th Jul 2013 7:02pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Get MSS ones as they are bolted in on the inside.
28th Jul 2013 7:40pm |
I have the MSS guards in my 110 and really rate them. If you are interested I can post up a selection of photos I took when installing the guards?
Incidentally the interior style guards are awesomely useful when camping/overlanding... |
29th Jul 2013 7:24am |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
I made my own.
Only needed to drill 1 hole near the door Click image to enlarge [img]https://www.defender2.net/gallery/albums/userpics/10578/normal_DSC04380.JPG[/img |
29th Jul 2013 7:32am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Tack,, Read the title,, Window Guards !!
I have MSS internal ones,, No drilling required, bar the back door, 6 seft tappers holding the guard in,, Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
29th Jul 2013 8:00am |
Cheers for the photos Tack & TJ101, much appreciated. I just need to get my backside in gear and buy some now before I go away. Geobloke, photos would be gleaming if its no dramas?
Cheers once again Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
29th Jul 2013 4:17pm |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 |
TJ101 Do you need to remove the rear seatbelt brackets to fit the MSS quarter window guards? 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
17th Aug 2022 6:34pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1930 |
I’ve got the full flatdog cages and upper and lower shelves, great kit with no issues so had their rear window guard, used small rivnuts to fix in place 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
17th Aug 2022 9:57pm |
I have the MSS ones but can’t work out if you need to remove the rear seatbelt brackets in order to fit them, or if they go on top. I can’t get them to fit either way. 1989 90 4.3 V8
18th Aug 2022 5:33am |
