Home > Maintenance & Modifications > Mud Console and hazard lights switch |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6098 |
I would cut off the plug that goes on to the back of the hazard switch, and just solder/heat shrink on some extension pieces.
You may be able to pull the plug back some of the distance back to the "centre" of the dash, but I don't know how far it will reach. |
22nd Jul 2013 6:07pm |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
I have done the Mud-dsh & Carling Hazard switch modification and can confirm you will need to cut the wires at the old switch and add sufficient extensions to them to get to the new switch. You may be able to source some of the wires closer to the new switch but I can't remember which ones (earth, perm live, switched live??).
22nd Jul 2013 6:34pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 |
Yes, just cut and extend them using solder joints & heat-shrink.
Fitted a Raptor and used Carling switches throughout (inc Hazard) and looks very neat. ONE LIFE, GET IT! |
22nd Jul 2013 7:02pm |
Halge Member Since: 10 May 2012 Location: Rotterdam area Posts: 8 |
Ok! I was afraid that would be the job... Next weekend then...
Think it would make a nice extra thing to order with a Mud Console: a "plug-O-extention" cable for these 3 switches. Had a look behind the main dashboard clocks... my God what a mess! Saw a small dozen off loose and cut off wires. Also the interior lights feed that comes out of the switch (red/white) is completely toasted! Just bare threaths with too old isolation tape wrapped around it. I think I'll just disconnect that one and get a other one at the Mud Console. Thanx! Jelle |
22nd Jul 2013 8:43pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5852 |
I too was having the same thoughts over the Mudconsole and the three switches to the left of the steering wheel. I didnt want to cut them and then resolder the connections. 1999 Defender TD5 110
22nd Jul 2013 8:49pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2245 |
Replace those switches with Carling items, they're a bit more expensive but look and work far better.
23rd Jul 2013 11:50am |
I have the Carling switches ready to be connected.
Just hoped that there is some smart way for getting the wires to the middle. But it will be an old school solder job I'm afraid. |
23rd Jul 2013 7:20pm |
As an alternative, you could try these: |
24th Jul 2013 8:14am |
Great tip! Thanx.
I'll go find them in Holland. |
24th Jul 2013 11:11am |
