![]() | Home > Puma (Tdci) > TDCI Clutch Kit |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
Dead write, It was all or nothing. If you got it wrong at the lights you were waiting for the bang or road rage.
Allan |
WinBoot Member Since: 09 Jan 2010 Location: Ieper Posts: 28 ![]() ![]() |
Getrag Ford transmissions are working on a Powershift® Dual clutch transmission for AWD, so maybe just wait untill they have that finished? It would probably be the easiest way of modying since they've built the current one in the Puma TDCI also.
That's my guess atleast ![]() |
80 bhp is a good power gain if it can be done, but I dont know if you need to go down the clutch modification path. A LandRover clutch can handle some very hard work as standard. I have towed boats etc all over a ton and a half in weight all over Western Australia with the vehicle fully loaded on the standard clutch on my Defenders without any problems. Even on the Subaru sti it was only in need of a modified cluch after a 2.5ltr modified engine pussing 240kw at the wheels was fitted. In most situations a standard clutch will cope. Also if you are using it for rock crawling, or low range work I think it would drive you nuts
Allan |
Martin90 Member Since: 12 Feb 2010 Location: Abu Dhabi Posts: 19 ![]() ![]() ![]() |
[quote="mhill"][quote="Sonic3d"]
2.0Tfsi in a series 3, I bet that is fun! ![]() ![]() ![]() 1989 90 - Truck cab, Mazda 35 SLTi engine 2009 90 - Station Wagon |
mhill Member Since: 24 Jan 2010 Location: Tendring, Essex Posts: 46 ![]() ![]() ![]() |
[quote="Martin90"][quote="mhill"]
Very good indeed, never thought of it like that! |
