Home > Puma (Tdci) > LOST DISPLAY |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 |
Hi all,
My rev counter, speedo, temp gauge and fuel gauge have stopped working. Initially it had failed to start and fuse 30 had blown ( int light and radio) my scangauge still registers the rpm but no mph. the rev counter has no lights at all! I have checked fuses and relays for secure fitting, do you think it could be the main earth? |
5th Jul 2013 1:10pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Mine too!
Everything else is working. Fuses appear ok. No speedo, revs, trip meter, fuel or temp guages. www.ralton.co.za |
6th Jul 2013 7:47am |
I've just pulled all the fuses out and replaced them again.
Problem solved. Bloody Defenders! www.ralton.co.za |
6th Jul 2013 12:57pm |
You little beauty, just disconnected battery for 5 mins and display is back.
Too hot to go for a run at the moment, will test run later:-P B-) |
6th Jul 2013 1:28pm |
defenders ... don't you just love'm
6th Jul 2013 3:16pm |
