Home > Puma (Tdci) > LOST DISPLAY
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
LOST DISPLAY
Hi all,
My rev counter, speedo, temp gauge and fuel gauge have stopped working. Initially it had failed to start and fuse 30 had blown ( int light and radio) my scangauge still registers the rpm but no mph. the rev counter has no lights at all!
I have checked fuses and relays for secure fitting, do you think it could be the main earth?
Post #249247 5th Jul 2013 1:10pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Mine too!
Everything else is working. Fuses appear ok.
No speedo, revs, trip meter, fuel or temp guages. www.ralton.co.za
Post #249491 6th Jul 2013 7:47am
I assume you have taken the binnacle cowls off and checked the multiplug?
If the binnacle is U/S then the good news is they are only about £160, the bad news is LR need to install and configure... unless any of the tuning companies can do that now
Post #249492 6th Jul 2013 7:58am
ralton
I've just pulled all the fuses out and replaced them again.
Problem solved.
Bloody Defenders! Rolling Eyes www.ralton.co.za
Post #249536 6th Jul 2013 12:57pm
foxkilla
You little beauty, just disconnected battery for 5 mins and display is back.
Too hot to go for a run at the moment, will test run later:-P SmileSmileB-)
Post #249539 6th Jul 2013 1:28pm
defenders ... don't you just love'm Thumbs Up
Post #249560 6th Jul 2013 3:16pm
